Weird DPO wires heating up really hot
RickB
My 'missing / cutting out' problem came back, so once again I started looking all over and after shutting off the car the other day I happened to put my hand on the wiring 'harness' coming out of the firewall on the drivers side.
It was <span style="font-weight: bold">HOT</span>.
I cut away the blue tape to reveal my white wire from the coil to the cockpit was the one getting really hot.
It was spliced into two other white wires going 'who knows where'.
One of these was a white wire that just headed out towards the front of the car. I know of nothing that direction that should be in that circuit so I cut it and started the car again, the wiring no longer gets hot.
What in the world was the DPO thinking? Why connect up wires to that circuit - I can't think of anything up in the engine compartment that should be on that circuit except the coil.
My cutting out problem was still there this morning, though it seemed about 75% less. I still have a problem, just not sure where. Have to find out where that other white wire is connected.
Never underestimate the powers of the DPO!!
Deleted member 8987
Relay for auxilliary cooling fan?
If it's gotten that hot, chack your voltage at the power side of the coil while running.
I don't think that car is a "resistor" fed coil, so the chances are pretty high you have a high resistance point in the splices or elsewhere dropping voltage to the coil.
If non-resistor coil, power side of coil should read battery voltage.
If you can't see much difference, check from positive side of battery (if negatively earthed) to power side of coil while running....which will give you the exact amount of drop.
RickB
RickB
Might have been at one time, but that's not how I wired it.
I'll check that tonight. Might be that other spliced in wire also was used to activate a relay, I'll follow it and find out.
Morris
Hey Rick,
The 1500 was originally wired with a "resistor" wire that splices into that coil feed and runs to nothing in the front of the car. The 1500 coil in factory trim was an externally "ballasted" coil. The resistor wire gets hot by design. On my car, that wire is a very light pink (almost white) if I remember correctly... and I may not.
If removing what may have been the resistor wire affected your sputter problem... I would have a long hard look at your coil. If you were running an internally ballasted coil on that resistor wire, you may have fried it.
Deleted member 8987
If that's a resistor wire (still), and there are two taps off it, one of which overloaded the resistor wire until it was hot, I wonder where the other wire goes? Still need to know the voltage at the coil, running.
Don't recall a 79, but most 12V systems with a wire resistor give about 8-9 volts, running.
Could be an internally resisted replacement coil on a wiring loom resistor, giving far less output than it should.
This the one you had to jury-rig a replcement ignition switch into?
RickB
RickB
Yes its that one.
Datsun 1500 motor. For "some" reason the ignition wiring was over heating.
Bought a new coil for it recently, so it is the one for the engine not the car.
I have no idea what the DPO did to adapt the electrical system but clearly it's not perfect.
I had to do home maintenance after work rather than car maintenance.
Deleted member 8987
Okay, coil for engine not car can be an issue.
You need to find out if the Dat Soon coil requires an external resistor or not (possibly NAPA can tell you). If the coil requires no external resistor, you will need to run another "hot" lead down the harness from the "ign" post on the switch to the coil, connect at both ends after disconnecting (and taping) the old wire.
RickB
RickB
That actually sounds like a very good idea, I'm a fan of the new wire when the old is questionable.
I can find out about the coil needing / not needing a resistor today.
Deleted member 8987
Keep me posted. Today is not a good day to run up past the Falls, but mayhaps tomorrow.
Dave
RickB
RickB
Tomorrow I'll be at Bill's house (BillM) pulling the drive train again. We need to diagnose and fix a slipping clutch.
Maybe I'll stumble across whatever is causing the misfire while we are at it.
RickB
RickB
The resistor was not used so cutting it loose was correct.
Now I just need to locate the cause of that misfire and get a good working clutch in the car.
And do some body work
And get it painted
And make sure all my brakes are good
And put in new valve seals
And... And... And... And... And... And... And... And...
Drive to Wisconsin and back!!
Deleted member 8987
Okay, if no resistor on the Dat Soon coil, run a new non-resistor hot wire from ignition to coil.
Then, find out where that other spliced in wire went.
RickB
RickB
Now that's a good plan! I'll do it that way.
Thanks!
Deleted member 8987
I sent BillM a PM, maybe if he approves, I can swing by tomorrow.
I have a couple of pieces of test equipment, if it's running, to check spark intensity at the plugs and dwell, that kind of stuff.
Dave
RickB
RickB
Thanks Dave, we're going to start the removal process today after work then finish the job tomorrow. Hopefully this way we can get done before it gets late.
RickB
RickB
Engine will be out for several days to a week.
EricJNewman MGB Weird Brake issue finally solved. MG 1
JPSmit Vauxhall question - I know, weird eh?! Lotus 6
Rob Glasgow Weird Lucas Headlight Austin Healey 7
H weird things painted by hand with a brush Austin Healey 6
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
roscoe Distributor problem [a bit weird] Austin Healey 15
Rut MGB OK, I must attract weird MG 5
Rut MGB Weird oil question MG 3
P TR6 Another weird problem Triumph 6
V Weird Brake Issue Austin Healey 18
T TR4/4A Weird starting issue with my TR-4 Triumph 15
D Weird motor mount?? Spridgets 7
aeronca65t Weird things spotted......not cars Spotted 3
aeronca65t Weird Whatzit Spotted 2
Jim_Newman MSD Ignition and weird run-on Austin Healey 4
GBRandy Spot Free! - am I weird??? Triumph 10
rlich8 What was your weird problem today? Triumph 21
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
Moseso Weird Hydraulic Failure Triumph 8
eschneider Weird oil leak? Triumph 12
I Weird indicators on BN1 Austin Healey 4
M Weird Happenings w/My Speedo Spridgets 2
bighealeysource engine running weird on my BN6 Austin Healey 6
AngliaGT Isn't it Weird ........ Other Cars 12
T weird oil leak - BJ7 - a question Austin Healey 4
P weird thing with midget clutch pedal Spridgets 3
bcbennett Weird idling problem Triumph 3
jvandyke weird half top, soft targa? Spridgets 10
healeyboz another weird request Spridgets 1
Got_All_4 Weird R&R the turn signal switch and horn blows Triumph 8
G This may sound weird but.... Triumph 15
aeronca65t Tons of weird cars Other Cars 3
rlandrum Weird block holes Triumph 6
Raymond weird brake light problem MG 4
John Moore Weird Lug Nut Question Spridgets 9
Morris Weird Cooling Problems Spridgets 15
tony barnhill Today's Weird Question MG 57
Morris Weird paint question Spridgets 14
T Weird realization MG 2
aeronca65t Weird Brit Stuff Other British Cars 20
Mickey Richaud Well, This is Weird... Triumph 16
vping Weird fuel pump MG 13
B Weird Fuel Pump Issue MG 1
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
GregW Weird timing light readings Austin Healey 8
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
D Something weird with the idle/throttle Spridgets 23
Sherlock Weird Mini fastback in Australia [Mini Monaco?] British Motor Corp 22
tony barnhill Weird Little bug eye Spridgets 8
A How weird is this... MG 6
