tony barnhill
Great Pumpkin - R.I.P
Okay, here's today's question:
1. Fuel pump is pumping gas yet bowls are empty (checked to make sure it was pumping by holding gas line in a bucket).
2. Removed top of both bowls/floats & pumped gas into them directly from the gas lines (rear carb line flows first & front carb line doesn't flow unless rear bowl is full) .
3. Replaced tops/floats onto full fuel bowls (&reconnected fuel lines to bowls).
4. Started engine & ran until it died - opened bowls & both were empty.
5. Disconnected fuel line from bowls individually & both pump fuel.
6. Filled both bowls again, hooked up fuel line & engine runs until both bowls are empty.
7. Yet, fuel is pumping out into a bucket when lines are disconnected from bowls.
Why are the bowls running empty when fuel is being pumped from rear of car to them?
