TR2/3/3A TR 3A Accelerator Bushing Placement
Tinkerman
My goal today was to install the accelerator assembly. I have been working with it off and on for the last two weeks. I finally got it installed and I suspect that there is a problem. I was pondering the placement of the bushing holders. I researched everything I had, looked at all the pictures I have but, it was a hidden item everywhere I turned. I figured that it was fifty/fifty on the placement so I rolled the dice and decided to mount them under the dash. See the pics. I suspect I made the wrong choice. So my question is, are they mounted on the outside of the bulkhead, inside or one of each? I will sit here, have a cold adult beverage, contemplate my future as an automotive restorer and await the answer. Scheech, I hate do overs!
Thanks, Tinkerman
Mkutz
The bushing holders are mounted on the engine side of the fire wall. At least that is how they are on my car.
M_Pied_Lourd
Tink,
Just going to run out to the garage and snap some photos. Mine is still on the tub.
BRB.
Cheers,
M. Pied Lourd
M_Pied_Lourd
K. Here are some photos, hope that they help.
Cheers,
M. Pied Lourd
angelfj1
Dick: There are bushing retainers at both ends of the cross-shaft. Each retainer consists of an inner and outer plate as shown below.
Tinkerman
Tinkerman
Thanks for the PIC's MP, I of course have it wrong. I noticed in the third picture, the white car has a bolt and nut holding the throttle lever on to the shaft. I guess someone got tired of fussing with the mills pin. I will take it out and try to get it right this time, sigh!
Thanks to all of you for taking the time to help me out.
Tinkerman
TexasKnucklehead
Tinkerman,
I doubt it will matter in the way it functions. Someone will have to look hard and know better and notice. I think I'd let it be. Mine had a bent nail through one side and the holes needed redrilled and new pins installed (I used split pins).
In the 3rd picture, where is the other end of that spring?
Tinkerman
Tinkerman
TexasKnucklehead said:
Tinkerman,
The other end of that spring should be attached to the linkage lever. I suspect he undid it at some point along the way.
Tinkerman
TexasKnucklehead
Right. One end attaches to the linkage. Does the other end have a special attachment point, or does it just go under the inner fender well ?
martx-5
Here's what I wound up doing for the accelerator linkage.
I used a couple of self aligning bushings from McMaster. I did a little re-engineering also. I made a new sleeve where the pins go on the driver's side to connect the cross piece to the pedal. I eliminated the step in the sleeve, and it rides in the new bushing. The pic with the new sleeve doesn't have the pin driven in yet, but to disassemble everything, all I have to do is drive that pin out, then I can extract the pedal from the bushing. You can see that in the last pic. Unbolt the cross piece from the firewall, and you can extract it from the other bushing by pushing into the vacated bushing on the driver's side. Since there's a lot of slop going into that bushing without the sleeve on there, it's very easy to get the cross piece out. IIRC, the ID of the two bushings are different sizes.
The whole system turned out to be very smooth acting.
Tinkerman
Tinkerman
That really looks great Art. I finally got mine in. Still have to put the pin in. So, pin, two self tapping screws and its done. I really like your rig much better. Installing the accelerator assembly has to rank right up there with one of the tougher jobs on the TR 2,3.
Thanks for the pics. I enjoy seeing great craftsmanship!
Tinkerman
martx-5
Yes, it is a tough job, especially when the engine is in place. Although I did all of the work without the engine in, I wanted to make it so <span style="font-weight: bold">when</span> the engine was in, I could get it apart without to much of a hassle if need be. I still have most of my hair left, and didn't want to be subjected to pulling it out because I had to change some accelerator linkage parts. :laugh:
M_Pied_Lourd
It is one of the only things left on my car....kinda dreading taking it out now...looked for the mills pins once...couldn't find them so I gave up temporaily :wink:
Cheers,
M. Pied Lourd
Tinkerman
Tinkerman
Mills pins are now what I call roll pins or split pins. I bought some from MOSS and I could have used one from my assortment bought from several years ago. In fact if you need some let me know I'll send you a couple. I have the original that I took out and it is a solid pin. That's the type I'm familiar with and in fact, I might use it to replace the nail I have in there now. I took it apart and got all of the parts out, after I found that I put it together wrong. I put the rod in with the front bushing back into the car, just checking everything, you know. I could not get the accelerator rod with the pedal back out! I fussed with that for about two hours. Gave up, put it all together and it's done.
Should have done that while the engine was out. On top of all that I had some issues with the drivers side of the side wall. As in not being flat! Had to do some shimming to get it all to work. I'm too far along and could not get a good swing with the hammer to get it all straight.
I really like Art's set up!
I love automobile restoration, that's right isn't it?
Cheers, Tinkerman
TR4nut
Here's a pic showing that spring in place, hopefully it is correct as it is also the last thing on the body that I haven't disconnected:
The spring attached to a small tab on the body - the spring looks a lot like the spring for the clutch return on the clutch slave.
M_Pied_Lourd
I just dug up a photo of mine before I disconnected it.
Randy, yours looks cleaner than mine!
Cheers,
M. Pied Lourd
TR3driver
Great Pumpkin - R.I.P
Similar size & length, but the spring for the clutch slave should be a LOT stiffer.
TR3driver
I could be mistaken, but I believe those are actually 3 different (though similar) things.
A "Mills" pin is solid, with grooves pressed in the sides to give it some bite in the hole (almost like just two lines of knurling on opposite sides of the pin). The grooves are typically deeper towards one end, giving the pin a bit of taper (but not enough to qualify as a taper pin).
A "roll" (or "rolled") pin is actually a thin sheet of metal rolled into a cylinder, so that the ends overlap.
A "split" pin is a somewhat thicker sheet of metal, rolled into a cylinder so the ends don't quite meet.
In some cases, a split pin (which is much more common and cheaper) is an adequate substitute for the other two types. However, a roll pin is more flexible and stronger and will accommodate more variation in hole size than a split pin; while a Mills pin is more rigid than a split pin and stronger then either rolled or split pins.
TexasKnucklehead
Thanks Randy -and Randall.
As you can see in my picture, the car came with a spring jammed under the fender-well, which didn'd look right to me. The nail wasn't a good substitute for whatever pin should have been in there (mills I assume) and caused the holes to be out of round. I figured a split pin could be used since the sheer strength should not be an issue -assuming the pedal stop is adjusted to the full open throttle position, even though the pedal is bent. I thought of using a cotter pin, but decided to avoid any risk of it coming apart and sticking the throttle. So I drilled the holes larger, drove in a split pin, and mushroomed the ends so it couldn't fall out and painted it.
I also opened up the "bearing" hole on the drivers side a little so the assembled linkage can be fitted without scratching the car or linkage (from the engine bay). -Assuming I ever get to a point where I start putting things back together.
Now I see there is a little tab to atach the proper spring on my car too. I have no idea why it wasn't used, and noticed that little tab when I was working in the engine bay some time ago.
Tinkerman
Tinkerman
That's kind of interesting, Randy's picture shows the ball stud to the left of the linkage lever. On mine the ball stud is to the right of the linkage lever. Easy enough to switch depending on the linkage. My accelerator assembly is not native to my car. It came from Ebay. Mine was a rusty lump so had to go.
Thanks Randall, for the info on the various pins. What I got from Moss were split pins.
Tinkerman
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
Musicman That Dreaded Accelerator Bushing Triumph 5
CARSINC MKIII Accelerator Pedal Spridgets 0
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
FlyingCat Spitfire Accelerator cable Triumph 4
B LHD to RHD accelerator controls Austin Healey 15
K For Sale TR3 Accelerator pedal assembly Triumph Classifieds 1
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Got_All_4 TR2/3/3A Accelerator shaft question Triumph 2
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
M Accelerator Pedal Position Austin Healey 4
R TR2/3/3A TR-3A accelerator return spring Triumph 9
PatGalvin TR2/3/3A Accelerator Pedal Advice Needed Triumph 21
G Best way to remove accelerator bar part # 106762 Triumph 3
K TR2/3/3A TR3A...Kicking accelerator pedal lowers idle? Triumph 20
S XKE Accelerator Ppedal Position Jaguar 2
B Accelerator relay rods on RHD Austin Healey 2
bcbennett TR6 TR6 accelerator vibration Triumph 9
ArcticOne GT6 GT6 Accelerator Pedal Removal Triumph 8
ArcticOne GT6 Accelerator Pedal - GT6 MKI Triumph 2
bigjones MGB MGB accelerator cable MG 8
I Source for Bugeye accelerator return spring? Spridgets 2
ArcticOne Accelerator Pedal Triumph 0
I TR6 TR6 accelerator bar busing replacement help please Triumph 10
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
TR6oldtimer TR6 TR6 accelerator linkage help needed Triumph 9
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
B accelerator cable Spridgets 6
Tinkerman TR2/3/3A Accelerator Assembly Installation TR3A Triumph 3
Tinkerman TR2/3/3A TR3A Accelerator Assembly Triumph 6
Tinkerman TR2/3/3A TR3A Accelerator Pedal Assembly Triumph 9
Tinkerman TR2/3/3A Accelerator Pedal Assembly ,TR 3A Triumph 6
Tinkerman TR2/3/3A TR3A Accelerator Rod Dissasembly HELP! Triumph 1
glemon TR5/TR250 TR250/6 accelerator shaft bush Triumph 5
D MK2 accelerator pedal Jaguar 0
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
Morris 1500 Accelerator cable Spridgets 7
angelfj1 TR2/3/3A TR3A accelerator pedal/shaft Triumph 9
T Clutch and Accelerator return springs are missing Triumph 6
R Accelerator linkage removal Triumph 2
Tinkerman TR2/3/3A Accelerator Pedal Question TR3A Triumph 5
B Accelerator Cable Spridgets 4
M TR2/3/3A TR3 Accelerator Pedal Triumph 7
Tinkerman TR2/3/3A TR3 accelerator pedals Triumph 8
Atrus Accelerator Pedal Spridgets 7
J Spitfire Spitfire MK3 accelerator bushings Triumph 3
Tinkerman TR2/3/3A Accelerator rod pin removal, TR-3 Triumph 0
Johnny Accelerator linkage restoration Austin Healey 34
