Accelerator linkage removal
r66
Member
I am trying to remove the accelerator linkage on my TR4A. How do I remove the mills pins? Just knock or drill them out?
Thanks-Ron
Brosky
Ron,
You're not being ignored. I can tell you TR6 procedure, but I've never done a TR4.
Someone will be around soon, I'm sure.
TR4
Thanks-Ron
I am not familiar with the term mills pin. Are you talking about the Clevis Pin on the throttle shaft under the dash? Can you tell us the Moss Part number?
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
TR6oldtimer TR6 TR6 accelerator linkage help needed Triumph 9
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
Johnny Accelerator linkage restoration Austin Healey 34
G Accelerator Linkage Slop Triumph 14
CARSINC MKIII Accelerator Pedal Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
FlyingCat Spitfire Accelerator cable Triumph 4
B LHD to RHD accelerator controls Austin Healey 15
K For Sale TR3 Accelerator pedal assembly Triumph Classifieds 1
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Got_All_4 TR2/3/3A Accelerator shaft question Triumph 2
M Accelerator Pedal Position Austin Healey 4
R TR2/3/3A TR-3A accelerator return spring Triumph 9
PatGalvin TR2/3/3A Accelerator Pedal Advice Needed Triumph 21
G Best way to remove accelerator bar part # 106762 Triumph 3
K TR2/3/3A TR3A...Kicking accelerator pedal lowers idle? Triumph 20
S XKE Accelerator Ppedal Position Jaguar 2
B Accelerator relay rods on RHD Austin Healey 2
bcbennett TR6 TR6 accelerator vibration Triumph 9
ArcticOne GT6 GT6 Accelerator Pedal Removal Triumph 8
ArcticOne GT6 Accelerator Pedal - GT6 MKI Triumph 2
bigjones MGB MGB accelerator cable MG 8
I Source for Bugeye accelerator return spring? Spridgets 2
ArcticOne Accelerator Pedal Triumph 0
I TR6 TR6 accelerator bar busing replacement help please Triumph 10
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
B accelerator cable Spridgets 6
Tinkerman TR2/3/3A TR 3A Accelerator Bushing Placement Triumph 21
Tinkerman TR2/3/3A Accelerator Assembly Installation TR3A Triumph 3
Tinkerman TR2/3/3A TR3A Accelerator Assembly Triumph 6
Tinkerman TR2/3/3A TR3A Accelerator Pedal Assembly Triumph 9
Tinkerman TR2/3/3A Accelerator Pedal Assembly ,TR 3A Triumph 6
Tinkerman TR2/3/3A TR3A Accelerator Rod Dissasembly HELP! Triumph 1
glemon TR5/TR250 TR250/6 accelerator shaft bush Triumph 5
D MK2 accelerator pedal Jaguar 0
Morris 1500 Accelerator cable Spridgets 7
angelfj1 TR2/3/3A TR3A accelerator pedal/shaft Triumph 9
T Clutch and Accelerator return springs are missing Triumph 6
Tinkerman TR2/3/3A Accelerator Pedal Question TR3A Triumph 5
B Accelerator Cable Spridgets 4
M TR2/3/3A TR3 Accelerator Pedal Triumph 7
Tinkerman TR2/3/3A TR3 accelerator pedals Triumph 8
Atrus Accelerator Pedal Spridgets 7
Musicman That Dreaded Accelerator Bushing Triumph 5
J Spitfire Spitfire MK3 accelerator bushings Triumph 3
