NutmegCT said:
what did you change to stop the linkage rubbing on the bolt head? Do you have an "after" picture?
That IS the after picture! (about 2 years after) I unfortunately didn't take any "before" pictures, partly because I just didn't think of it, and partly because I didn't remove the carbs at the time. The main change was to insert a bushing into the bellcrank (cut from a piece of thinwall brass tubing from the local hobby shop). But I also ground away a bit of the bolt head, to increase the clearance. The bolt originally had some kind of raised logo on the head.
I'm also going to try to remember to put a drop of oil on that joint once in awhile (which is why it's so dirty), along with all the other moving joints in the throttle linkage.
Heim joints might last longer; but honestly, are you worried about having to replace those joints again in another 50 years? Heavy duty trucks use the same kind of joints and they last for literally millions of miles.
It doesn't happen often for me, but I have had situations where the carbs got hot enough for the fuel to boil. For example, last summer my Dad & I went on a run with the local club starting from the high desert and going up into the San Gabriel mountains. Even in the mountains, I'd estimate the air was 80+F and the sun was bright, a beautiful day. But, after we made a 5 minute "pit stop" at the top of a grade, the TR3 was very hard to start, blew black smoke, and didn't want to idle. (I wasn't the only one.) So, I'm hoping the carb shield will help with that.
I'm not too worried about starter access; I've never had a moments trouble since switching to a gear-drive unit back in 2001. But before that, the big Lucas wouldn't come out the top without removing the rear carb anyway. I found that, with some careful prying against the motor mounts, I could work it out the bottom. I also added a Helicoil to the top starter hole, to make it easier to install without removing the carb.
I also have a feeling that the rather toasted appearance of the float bowl gaskets
has something to do with excess heat radiating from the exhaust manifold.
