TR6 TR6 accelerator vibration
bcbennett
Does everyone's TR6 accelerator pedal vibrate like crazy around 55 mph, or just mine? It seems to be smooth up to that point, and it can smooth out past 60, but man oh man...it gives my foot quite the massage in the interim. Thoughts?
M_Pied_Lourd
Sorry BC, don't have that experience on Mine. Might be great for longer drives though to get the blood flowing :0)
Cheers,
M. Pied Lourd
Gliderman8
I can't imagine that the pedal is vibrating... it may be transmitting the vibration. I'd look at other areas before I would think it was the pedal. Drive shaft out of balance? Tires?
SkinnedKnuckles
That's weird. Doesn't happen on mine.
kodanja
maybe yur linkage is loose?
tomgt6
Check the motor mounts maybe as well. They may be just getting loose or getting old.
poolboy
And check the bushings on both ends of the horizonal part of the shaft as it passes thru the body sheet metal.
tomgt6
Thought of one other items. When you get the pedal down to that point could it be touching something along the way. Maybe up by the carbs or maybe a bolt or something on the engine or tranny.
Have someone push on the peddle and look to see if it touches something at some point.
I TR6 TR6 accelerator bar busing replacement help please Triumph 10
TR6oldtimer TR6 TR6 accelerator linkage help needed Triumph 9
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
