I am refering to shaft that lis located on firewall and retained in a bearing on each side and is used to connect gas pedal to carbs.
What is the easiest way to remove this from the firewall. It appears that this can be removed either by removing the two mill pins on the left or the mills pin on the right. Any suggestions on how to remve this assembly? Is the removal of the pins the only way to remove this assembly? My intent is to remove the plastic bearings on the shaft prior to having the tub tipped.
