best tool to remove old bondo ?
beaulieu
I have been stripping down the front of my project which had been customized with flared fenders , and other tailights , turn signals
this was done in the 70s and they used tons of bondo
so is there any trick to get it off ?
I have used a grinder with one of the flapper wheels , and also tried the 3m paint stripper wheel with the mesh fibers,
any other ideas ?
If there is this much bondo so far I am sure there is more !
thanks
Beaulieu
G
I can't remember the brand, but I bought some paint stripper from one of the home centers and it softened the bondo enough to where it was easier to get off. It made it kind of rubbery texture. You can also try other solvents such as acetone or lacuer thinner. But they might flash off too fast.
GregW
Platinum
Hi Beaulieu,
Marhyde aircraft stripper will melt the bondo, but it will take several coats to remove thick layers (local auto parts chains usually carry it). I’ve also had good results with a heat gun. It will soften the bondo enough to scrape off. Any way you slice it, there is a fair amount of labor if you do it yourself.
beaulieu
beaulieu
well I either do it myself or pay a shop $40-$60 an hour to do it ,
its just grunt work , I am just trying to do it the easy way if there is one /ubbthreads/images/graemlins/smile.gif
Beaulieu
Darwin
Bronze
I just got done with this process. Trust me there ain't no easy way. Best thing I found was a wire wheel in a drill or angle grinder for the heavy stuff and the 3M fiber paint and rust wheel for ligher stuff and finish cleaning.
Edit note: Wear a dust mask and eye protection, the dust is nasty stuff to breathe and hard on the eyes.
PC
[ QUOTE ]
...I am just trying to do it the easy way if there is one /ubbthreads/images/graemlins/smile.gif...
[/ QUOTE ]RDX come to mind. /ubbthreads/images/graemlins/devilgrin.gif
PC.
martx-5
Propane torch. That's the most effective method I've used. Try and heat the metal next to the bondo and then scrape it off as it softens.. You can heat the bondo directly, but if you set it on fire, it's pretty acrid stuff.
beaulieu
beaulieu
doing a google search brings up many referances to using a propane torch ,
any tips on doing it that way ,
trying to keep away from chemicalls
thanks
Beaulieu
Keoke
Yes the torch technique is one of the best methods to use. However, a commercial heat gun and a scraper works very well too and is much safer.---Keoke- /ubbthreads/images/graemlins/yesnod.gif
fmichaels
i've had limited success with a heat gun but a torch sounds better. heat seems to work better than aircraft stripper and that's saying a lot since aircraft stripper is some nasty stuff.
beaulieu
beaulieu
well hopefully I will get out there Saturday and see how the propane torch works,
Aircraft stripper is just too nasty to use for me.
Beaulieu
beaulieu
beaulieu
well I tried stripping today......
1500 watt heat gun works , but takes too long (maybe the bondo was too thick) and sometimes would only take off the paint layer.....
Propane torch , all I had was a regular round tip , this worked much better , got the bondo soft , and if I left it on too long dried out the bondo so it was easy to remove ,
probably would be better with the wide tip. I used a 2 inch putty knife to scrape it off...
It is easy work , but after an hour or so your arms / wrists are hurting as its not something you regularly do , and the propane cylinder starts to get heavy !
I think I will look for a set-up that uses a remote larger tank like the plumbers have.....
Also bondo / paint catches on fire , so work outside and try to not have too many leafs around ( Dohh )
overall not so bad , will work on it so more tomarrow when I go to Walmart and get another propane cylinder
Beaulieu
martx-5
Ah, significant progress. The propane torch is the least messy of all of the alternatives there are for removing bondo. Sounds like you have a ton of bondo to remove, as it's time for more propane cylinders.
jackq
Years ago I bought a pneumatic tool called a gasket remover..anyhow, it has a blade on the end and you can put it against the palm of you hand and hit the trigger...just a light vibration. One day I had a car with a huge layer of bondo and got the idea to try the tool. Hit it with the tool and the stuff flew off. Once it got deep and under the crap it took just a couple of minutes. I'll get a pic today and post it.
beaulieu
beaulieu
ummm good idea about the gasket remover
I was also thinking of a needle gun,,,,,,never had one but it also looks like it might work
Beaulieu
JPSmit some days your best tool is a credit card Spridgets 2
T TR2/3/3A What is best tool, and best method, for widening gaps on TR3A grille? Triumph 21
J Best tool for getting help in the garage. Restoration & Tools 13
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
