Timer for pusher fan
warwick-steve
Hi
I have fitted an electric pusher/blower fan with a on/off switch for when I am in slow traffic and for when I turn the engine off. Is it possible to fit some kind of 12v timer into the circuit so that when I park up and walk away from the car the fan will switch off after a preset time? Any one know of a suitable timer?
Thanks
Steve
Warren
[h=1]Derale #16759 Adjustable Fan Controller. A good one. Available @ Amazon, Summit Racing etc. Works like a charm. I replaced 3 or 4 cheapos until this one.[/h]
RAC68
Steve,
My TR7 had Air Conditioning with a heave York compressor. Seeing little use for this old system, I removed all the air conditioning components as well as the puller engine-mounted fan from under the hood and left the 2 auxiliary fans. These auxiliary fans were mounted on an upward angle in front and below the radiator so as not to block air movement through the radiator when the car is moving forward. Additionally, and specific to your objective, these fans are thermostatically controlled (on and off) with a sensor on the upper tank of the radiator.
As I remember, there is a plug on the bottom of the top tank of the Healey's radiator. If you can get an adjustible thermostatic switch that can be made to fit into that opening, you can adjust the control to start by a set temperature or manual switch and automatically turn off when the engine temperature drops to a set temperature.
Just a thought,
Ray(64BJ8P1)
Patrick67BJ8
This what I’m going to be doing to replace the first setup I did.
Deleted member 21878
Steve
i am in the process of adding a pusher fan to my car and thought i remembered reading this thread.
The Beuler BU508TD timer relay might be what you are looking for. i am going to give it a try.
warwick-steve
warwick-steve
Hi Drone Dog
Thanks for the info.
I have just purchased a Kemo 12volt Time switch which incorporates a relay which is wired into the fan circuit. It can be switched on using a small button and switched off using a second button. Alternatively it can be switched off using the built in timer. The delay time can be adjusted between 2 seconds to 23 minutes. The timer and the two button switches including delivery from Germany was about £15.
cheers
Steve
steveg
Steve
This forum discusses this. One scenario they discuss is fitting a momentary switch so you can trigger the 2 minute relay when you want to rather than automatically. Seems like there would be many times where the car wasn't hot enough to warrant automatically running the fan at shutdown.
https://mechanics.stackexchange.com/questions/27954/time-delay-relay-and-flyback-diode
steveg
I used a similar circuit for running my anti-runon valve for 10 seconds at shutdown. I used a programmable timer which can handle up to 5A or can operate a relay for more. The timer has many different modes and there are YouTube videos explaining the programming which is pretty easy.
andrea
Hi Steve
I also have the pusher fan installed on my AH with the switch for heavy traffic situation -I solved the problem to cool at the run ending with a thermostat
that works in in parallel to the switch, it works also if I forget the use of the push fan when needed or if overheat occur
https://photos.app.goo.gl/n7hBFmqRAoQd4nST8
mgtf328
Hi steve,
Which model Kemo switch did you buy there seems to be more than one on ebay. I have a manually operated pusher fan and I left it on one time when I put the car in the garage and nearly drained the battery. Seems like I need one too!
AJ
warwick-steve
warwick-steve
Hi
I bought a Kemo M113A time switch and two T113A Miniature push buttons from Reichelt electronic in Germany.
cheers
Steve
Steve
so you use this timer/relay to turn on another relay the fan circuit is on?
Also if you have the timer set for say 3 minutes, do you have to push the on button every three minutes?
Michael Oritt
If the concern is for the fan's being left on and running down the batt why not simply power it via circuit that only goes hot when the ignition is on with a SPST between it and the appliance? This gives the option of having the fan come on--or not--automatically and there is no risk of running down the batt as even a Lucas 30 amp generator can cover its demand. If you want to have the fan operate after shutdown for a period of time and then shut down I'd suggest a thermostatically controlled switch rather than a timer but if you want the best of all possible worlds you have both in series.
I have my aux fan wired to the "always hot" fuse block--it is noisy enough so that I cannot leave it on inadvertently and there is less wiring and relays with which to be concerned. Though I am not too concerned with water temp when the engine is not running I do have the option of letting it run.
RAC68
Hi All,
I am a little confused in why a thermostatic actuation switch would not be better. You can always add an on/off switch if it is your desire to control the operation at times and also a timer if long term run-on is a concern. However, if you are going to take advantantage of having a pusher fan, why not really take advantage and let it do its thing when it is needed and eliminate having it on your mind.
Also, as I have experienced when trying out a pusher fan, placing it in the common position in front of the radiator behind the grill creates a block in the path of the airstreem from grill through radiator. Although this block does not seem to create an adverse temperature problem at driving speed, it can cause the electric pusher fan to be needed at a slow running speed when normal air flow would be sufficient to cool the engine and would require the pusher fan be active more often then needed without it acting as a block.
I have mentioned my use of (2) forward low mounted AC auxiliary fans aimed upward at the radiator in my TR7 (without AC) that are the only cooling fans. I find this mounting to be very effective as the forward upward angle of the air stream intersects at an advantageous angle with the cooling fins of the radiator and allow an unblocked air flow from grill through radiator. The fans are thermostatic controlled (no thought on my part whether to use or not) and are also controlled by the thermostat or a timer (which ever hits its limit first) when the ignition is turned off. Although I have also installed an on/off switch as a safety precaution to deactivate the fans manually, it has never been used in over 10 years in use.
Sorry if I am being redundant or missing something others are not,
Ray(64BJ8P1)
steveg
If someone in a cool climate (UK) feels the need of an auxiliary fan on their Healey, IMO they should first make sure their cooling system is optimum: Modern radiator core with 4 rows, overhaul it if older; backflush the block to remove silt; Texas kooler or 6-blade SS fan. Friends have installed oil coolers and report 5 - 10 degree temp reduction.
Ensure the accuracy of your temp gauge by measuring coolant temp at thermostat housing adjacent to temp bulb. I did that and found my gauge read 25 degrees high.
The TR7/Cobra setup of tilted fans blowing up at an angle is intriguing, but not sure how it would be implemented without cutting a new grille opening below the bumper.
IMO, Dougie's puller electric fan with shroud represents the ultimate electric fan solution.
RAC68
Steve,
Using a standard electric pusher fan would be difficult to mount low but keep in mind that the fan would be used in concert with a puller fan and should only be needed when the car was in traffic and not moving very fast. In this case, pulling air from below the shroud or through the grill would be very doable and should be sufficient to satisfy the air movement requirements of the fan. Also, below aiming upward toward the fan is one way but installing on the side would also work and be out of the direct air stream as well.
If I needed electrical fans to keep my Healey's heat under control, I would choose (2) smaller fans as used in most cars to support supplemental cooling for air conditioning. These would be easier to mount and keep out of the direct air stream and providing substantial cooling air movement during the times of slow or no movement (i.e. traffic on a hot day).
Prior to eliminating engine mounted or relying on the Air Conditioning fans on my TR7, I eliminated the engine-mounted fan and installed an electric pull fan (with shroud) and found it quite good. However, the Healey has little space to incorporate a puller electric fan and this unit was no exception.
Ray(64BJ8P1)
W TR4/4A Old Timer Triumph 14
R First timer posting in wrong section.. Spridgets 2
kaz2be First timer Triumph 18
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
4tecdog Pusher fans Spridgets 17
aero3113 100-4 Pusher Fan Austin Healey 12
C Where to wire a Pusher fan - BN1 Austin Healey 16
K TR2/3/3A Pusher Fan Again....Direction of airflow. Triumph 6
Lukens TR2/3/3A Installing pusher fan in TR3 Triumph 13
D Pusher or Puller Triumph 7
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S Heater and fan control replacement - any advice? Austin Healey 9
B Fan Blade Failure Austin Healey 6
D Fan Blade Austin Healey 11
B Revotec fan kit Austin Healey 4
B TR6 TR6 Fan Belt Triumph 4
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
