Pusher fans
4tecdog
Anyone got any feed back on the revotec fan, my main concern is not siting in traffic on a hot day but climbing the big hills we have here in Wales. I have to take care not to drive too hard uphill or I can see the temp climb to the 200 mark or even higher. Is the fan designed to reduce the temp in these conditions or will it have the opposite effect of restricting cool air to the rad by the very fact there is a big lump of plastic in the air flow.
Jim_Gruber
If the issue is at speed not in traffic time for a new radiator.
4tecdog
4tecdog
The rad was new 2k miles ago I do intend flushing and 40/60 antifreeze. I feel it just needs that extra air flow
nomad
In general once you are driving over 30MPH the fan doesn't do much. Airflow from speed usually is enough. Is the engine in good tune?
Kurt.
4tecdog
4tecdog
Yes all seems ok good colour on the plugs and advance working ok. I suspected airflow must be the case and I should not waste money on a fan. I will flush the system and re antifreeze and try and check the gauge, I know they are not always accurate but they are a good indicator (always go up when temp does! ) anyone tried water wetter to reduce temperature. Also colder stat ?
Rut
You may want to try a 50/50 mix on your antifreeze and water wetter wouldn't hurt. The water does a better job of cooling in the warmer months than the antifreeze does in my experience.
Rut
nomad
Ain't Barney Gaylord a wizard!? I've gone to MGA Guru for a number of things in the past and am always amazed.
Kurt.
Jim_Gruber
How about the water pump. How old is it. I've heard cases of worn impellers that don't circulate the amount of coolant they are supposed to. And there were two different water pumps on 1275's depending on the year of the engine. Could make a huge difference. And far cheaper as the next step. Also change the thermostat out , it could be sticking partially closed. After that and the water wetter the more expensive stuff will need your credit card to fix.
Morris
I have a pusher fan on my 1500 and cooling is never an issue even in the insane hot Texas summer. That said, I doubt it will address your issue. I have found that one possible source of mysterious overheating issues is a failing head gasket. So as you tick off your list, you may want to add a leak down test to eliminate that possibility.
4tecdog
4tecdog
Thanks for your suggestions I will be able to test most of them out over our holiday weekend this week, thought of buying a new stat from AH and notice it is a 72deg C is this the best one? Also tempted by the oil cooler they offer at a reasonable price.
4tecdog
4tecdog
Well went the whole package in the end fitted the 160 stat, flushed the rad, 50/50 antifreeze, added water wetter, removed pulley fan and fitted a revotec fan. Just completed an event covering over 300 miles with some enthusiastic driving and she held a fairly constant temperature never going over 190f happy now to the squeeling front discs.
4tecdog
4tecdog
Weathers back to normal now but wow we had some hot days earlier in the week, hottest June since 76 they say. Frogeyes temp never faulted really pleased with the revotech fan quicker warm up with no mechanical fan and a more steady temperature under way and in town traffic. No switches to flick a bonus.
nomad
Good to hear you have solved the problem. In my case I have two identical engines and cooling systems but my BE won't stay cool. I had the head off that very old engine a couple of years ago and believe its main problem is too much rust in the engine. Overhaul, I guess.
Kurt
Jim_Gruber
MOSS Europe has a slick Revotec Temp Sensor that fits in the lower radiator hose. Two additional radiator clamps and two short pieces of hose. For Bugsy IV I will like add a Revotec Fan and the In Line Temp Switch.79.95 Pounds IIRC.
4tecdog
4tecdog
Yes the sensor fits neatly in the bottom hose just have to remove about 30mm on the straight section and two s/s clamps just have to make sure the temp adjustment screw is accessible.
SD Bugeye
When I was living in Texas -Dallas area the problem i had was getting rid of hot air from the eng bay
what I did was remove the heater fan supply hose and that helped emensly
regularman
I ran two 1/2" copper pipes through the transmission tunnel and put an extra heater coil in the back with the differential to add extra cooling. I tied it in with Ts at the heater hoses at the heater. It removes a lot of heat from the engine and the engine compartment. I never put a fan on the heater coil back there but I have thought of it.
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
warwick-steve Timer for pusher fan Austin Healey 28
aero3113 100-4 Pusher Fan Austin Healey 12
C Where to wire a Pusher fan - BN1 Austin Healey 16
K TR2/3/3A Pusher Fan Again....Direction of airflow. Triumph 6
Lukens TR2/3/3A Installing pusher fan in TR3 Triumph 13
D Pusher or Puller Triumph 7
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Basil For you Bugeye/ Frogeye fans Spridgets 5
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
R Radiators , fans etc Spridgets 6
PC Morgan fans - how did I miss this? Other British Cars 2
tcherek For MORGAN fans ONLY Other British Cars 7
donbmw For the Bug Eye fans Spridgets 4
donbmw For the Bug Eye fans Austin Healey 1
AUSMHLY Any 1964 1/2 mustang fans here? Austin Healey 4
Mickey Richaud Any 914 Fans Here? Other Cars 1
DanLewis 'Just thought the rest of you Bugeye fans would want to see this! Spridgets 1
eschneider for you Minx fans... on evilbay. Other British Cars 2
T Plastic fans Triumph 11
glemon Fans and HP Triumph 14
J Electric Fans and Keeping Things Balanced Triumph 3
T Let's talk tropical fans... Triumph 1
luke44 Wedge Tr8 Cooling fans Triumph 6
RJS Aftermarket Cooling Fans Triumph 3
3798j For Triumph Fans British Motorbikes 2
3798j For BSA Fans British Motorbikes 2
KVH TR4/4A TR4 Cooling Fans Triumph 5
drooartz Generator and electric fans Spridgets 7
S TR2/3/3A Tr3 cooling fans again Triumph 1
J Radiator fans again! Austin Healey 5
S Electric Fans Spridgets 15
R Should Fans Turn on When AC is on? 1995 VPD Jaguar 2
C MGB Radiator fans - 1978 MGB MG 11
M Sad News for TVR Fans TVR 0
T TR6 TR6 fans - difference between years? Triumph 0
davidb For Morgan fans Other British Cars 3
W cooling fans Beware!! Austin Healey 9
kyreb1862 For The Real Project Fans Other Cars 1
W Calling all Jeep fans-got a wotisit? Other Cars 8
64rocksprite BE fans..check this out!! wall art! Spridgets 1
mailbox For Toyota fans, an interesting find Other Cars 2
bmurphy7369 Wedge TR7 DHC fans, advice on value/feasability of 1980? Triumph 7
Mickey Richaud Jeep Fans? Other Cars 5
6 Choice between 2 cooling fans: Recommendations? Austin Healey 12
S What magazines do LBC owners/fans read? British Motor Corp 6
Sherlock For you Cortina/British Ford fans... Other British Cars 16
H 2500M Came Originally With Electric Cooling Fans? TVR 19
L Spitfire Twin cooling fans on the Spit... Triumph 6
