Where to wire a Pusher fan - BN1
Crowbar
Member
Hello all,
I'm planning on installing an electric "pusher" fan from Moss on my BN1. The unit has a thermostatic switch, but I was wondering where I should splice into the wiring harness for power...I'm new to Lucas wiring and am understandable anxious!
Any advice appreciated!
Best,
GC
Michael Oritt
Use any terminal that is "always hot" so you can run the fan even if the ignition is off.
Though the unit you contemplate has a thermostatically controlled switch I recommend your using a regular SPDT switch in its place as there are times you may want to use the fan to get ahead of an issue--even before the temp rises to the preset point of the thermostatically controlled switch.
Use of a relay is a good thing. And a fuse.
Keoke
Connect the relay's primary power to "Any Terminal that is always hot".
Connect the switched relay power to the fan directly to the battery connection on the solenoid using an appropriately sized slow blow fuse.
:encouragement:'
vette
Hi CG, The first thing that I would want to know is, how many amps does the fan use? I want to say that you definately must put this fan on a fuse, and I also think that you definately want it on its own individual, manual, on/off switch. Many fans that I have read about can pull some high amps but here's the rule, if the device does not pull more amps than the amp rating of the on/off switch you are going to use, then you don't need a relay. The switch can turn it on and off, you don't need to step it down , around or thru anything just let the single pole switch do what it is designed to do.
The next point is what are you going to hook it too? If this fan pulls some high amps such as 20 amps, then you don't want to hook it to just any wire on the Healey wiring harness because you will easily be exceeding the rating of that particular wire especially when combined with whatever else is on that wire. Most the wiring in a Healey is sized just right for what it was originally intended to supply, it has almost no capacity for additional amps. Just for conversation sake, if you over load a wire, it will at the very least run hot (fire hazzard), it will also cause a voltage drop out to the devise you are trying to supply, the lower voltage out at the devise will cause the devise to try to pull even more amps and the devise will be damaged.
So, as stated in an early post, the hot terminal of the battery wire at the starter solenoid is about the only location where the supply wire (large wire coming from the battery) is large enough to supply some relatively, extra, high amps for a device such as a cooling fan. I would use size number 12 stranded wire because it is rated at 20 amps. You will quickly notice that it is larger than most the wire in a Healey. You will have to crimp a large eye connector unto this wire to put it on the large terminal of the solenoid. Make sure you get it on the wire coming from the battery. Then you will have to immediately go to an In Line Fuse Holder. I can't think of any reason why you would need a slow blow fuse. If this thing decides it wants to pull more than the fused rating (a short in the circuit or an jammed fan blade) I believe I would want it to blow the fuse as fast as possible instead of sticking around long enough to create more heat in the circuit. Since you are not pulling the circuit from wires that come thru the original fuses you will need this fuse holder. Then run the #12 wire from the fuse holder to either directly to an on/off switch or to a relay, which ever you decide. Size the fuse as what is stated on the fan name tag or as what the manufacturer says it needs, or maybe just a tesch higher. If the fan is labeled as in Watts instead of Amps then you can figure out the amps with this formula: Amps = Watts divided by Volts. Volts being 12. Good Luck.
Keoke
Note:
The fan is classified as an inductive circuit and if the fuse is rated at the fans steady state current, a fast blow fuse will blow every time the fan turns on.
When energizing electrical devices containing motors/solenoids use a slow blow fuse to protect the circuit.
Then the transient effects of the motor will be handled as well as the fault current in the event of a short in the circuit.
Michael Oritt
:encouragement:'
Keoke is right in commenting as he did upon what I said.
I have substantially rewired my car and brought 12VDC to two 6-circuit fuse boxes--one "always hot" and the other switched by the ignition key--into the engine compartment to make projects just like this easier. When I wrote the post I was thinking in my mind's eye the way my car is laid out versus stock.
In the original configuration there are not too many places to pick off a hot source that would be able to power a 20 A current, and certainly the starter solenoid would be a fine choice.
C
Crowbar
Member
This was outstanding information - many thanks!
Any advice on a good on/off switch?
The car is positive ground BTW...
Keoke
Next! upgrade convert to Neg Ground :encouragement:---:applause:
If you use the relay any single pole single throw switch that matches what is in the cockpit will work.--:cool:
warwick-steve
Hi all
Just been reading this interesting thread. I am also just about to install a pusher fan on my BT7 using a relay. I am clear that the switched side of the relay should be attached to the solenoid but what about the other side of the relay. I thought the brown wire on the fuse holder??
cheers
Steve
Keoke
Hi all
cheers
Steve
Relay contacts:------------------------- Not the coil winding connections
The unswitched side is connected to the solenoid's 12V power.
The switched side is connected to the fan via an appropriately sized fuse
does this answer your question Steve-?
Keoke
Hi all
cheers
Steve
The unswitched side of the relay contacts is connected to the solenoid's 12V power.
The switched side of the relay contacts is connected to the fan via an appropriately sized fuse.
The ["Other side of the relay"]One side of the coil winding can be connected to any power source that is always hot via a switch the opposite side of the coil winding is grounded.
Michael Oritt
Should you opt to use a separate switch for your pusher fan--as opposed to a thermostatically controlled one--there's the question of what kind to use and where to mount it. Some people don't mind separate switch panels but I don't think they look good, esp. on 100's.
The cleverest setup I have seen was on a 100 brought to stand for concours at a Conclave some years back--in this case for driving lights--but the same could be used for a fan or any circuit: The owner energized his dash lights through the side lights and utilized the small slider switch that normally controls them--through a relay of course--to the driving lights.
When the judges asked him how the lights were switched he challenged us to figure it out, which we couldn't, and made no deduction for correctness when he finally told us.
warwick-steve
Hi Keoke and Michael
Yes thanks
So a suitable power source for one side of the relay coil winding could be the single brown wire on the fuse box
thanks
Steve
warwick-steve
Gentlemen
Just to clarify something please. When you refer to a "hot power source", I presume this can be an unfused connection from the A1 terminal of the control box?? Like many new owners I am learning fast and really appreciate the help from those that have experienced with these things.
cheers
Steve
Keoke
Gentlemen
cheers
Steve
a "hot power source",Refers to a 12v source that is always " ON " or HOT.
For example the brown wire in the car harness.
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Boink Where would you wire an auxilliary outlet? Spridgets 35
K TR2/3/3A TR3A: Petronix Pos ground...which wire goes where? Triumph 6
F Where does this wire go ? MG 1
2wrench Help with where to place one more wire set Triumph 14
G Green/Purple or Red --- Which wire goes where???? Triumph 12
Tim_80B Positive wire for Tach goes...where? MG 2
kch Where do I get new wire wheels ? Jaguar 2
KLUTZ Starter Re-wire up. Which goes where? MG 2
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
