Temp. Probe for 1275 with Bugeye Radiator?
nomad
Thanks Dan. Do they tell you the exact temp or just if it's in the range?
Kurt.
DanLewis
Kurt,
I've heard that the strips are quite accurate, but I don't have anything other than the combination gauge in my dash to compare against. The strips have segments spaced at 5 degree Celcius intervals. The instructions that come with the strips say that they take on the following colors:
Green: Actual temperature
Brown: Just above actual temperature
Blue: Just below actual temperature
No information about relative accuracy is provided in the documentation.
Dan
Rut Bugeye 1275 temp probe placement. Spridgets 8
JFS TR2/3/3A Radiator fan temp probe Triumph 3
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
MikeAH100M High Temp Engine Miss Austin Healey 2
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
shadowfever Water temp Spridgets 9
Govtslug TR6 Coolant Temp Q Triumph 4
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A temp gauge sealer Triumph 7
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A removing the temp gauge needle Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
JFS TR2/3/3A Temp Sensor Removal Triumph 6
S TR4/4A Temp guage problem Triumph 5
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
Sopwith_Camel temp Jaguar 8
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
Got_All_4 TR2/3/3A Need a temp glass Triumph 11
B Temp gauge capillary tube Austin Healey 3
KVH TR4/4A Infrared Thermometer for Radiator Temp Triumph 6
Stewart MGB Temp sender issues MG 4
J Picture of temp gauge , Austin Mini British Motor Corp 2
Mink TR4/4A Temp gauge/sender question Triumph 15
N Temp Gauge No-Go Spridgets 5
A TR6 Temp gauge Triumph 11
C How to remove temp sensor at block? Austin Healey 16
R why winter and summer thermotat temp? Spridgets 3
J TR4/4A Fuel and Temp Gauge NightMare! Help! Triumph 24
R low/high temp engine running question Spridgets 23
