TR4/4A Temp guage problem
shoopal
Hi all
The temperature gauge reads 200 , the temperature at the sender is 165. What is the resistance curve of the sender ?
Or maybe the gauge itself is the problem. Or the voltage stabilizer?
Al
Merlin63Tr4
Is you fuel gauge reading accurately?
If the voltage stabilizer acts up it also affects the fuel gauge.
M.
HAWAIICJ
I used to have to turn on the headlights and blower to see the temp more accurately. Now i have a solid state voltage regulator!
S
shoopal
You all may have a point about the voltage. I put 5 gal in the tank and used up a bit of it running and testing. Gauge now reads 3/4. New tank sender. Still if I new what the resistance of the sender was at lets say 70 deg F, then I would know for sure before springing for one of those solid state voltage reducers. By the way, who sells them?
Merlin63Tr4
My temp sender reads 319.5Ω at 68ºF if that helps.
Solid state voltage stabilizers are sold both by Moss and TRF and probably others.
Just make sure you get the correct one (positive ground or negative ground).
M.
TexasKnucklehead
I recently had the same question asked from a friend here in Houston. Here is what I told him. He's been adding in-line resistance to get his measurement centered.
One big thing to take note of, is that the resistance measurement (with an ohm meter) of the sending unit, will significantly change as soon as the current thru the gauge is removed -in other words, the resistance is dependent on the amount of current used to measure it. (A regular ohm meter uses much less current than the 'temperature gauge' -which is actually another ammeter.) So, in order to get a realistic measurement of the resistance at a given temperature, you need to measuse the current thru the meter and/or voltage drop across the sending unit.
Anyway here's my chart:
44mA 160ohms shows 130 degrees
59mA 102ohms shows 170 degrees
85.6mA 52ohms shows 185 degrees
I ended up using a 51 ohm resistor in place of the sending unit/temperature probe, and calibrated my gauge to read 185.
I chose that value because I had 2) 102ohm resistors in parallel.. It also should be noted that I am using a LM2910 voltage regulator to control the input voltage to the gauge at 9.8v. With an ohm meter, my sending unit measures 75 ohms at 185 degrees.
Your results may vary, but I hope this helps a little.
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S Temp and Fuel guage not working Triumph 4
JohnnyMead TR2/3/3A TR3 - Routing the Temp Guage Tube? Triumph 5
pipercollins Running Temp, Guage, Sender Questions Triumph 11
mountainman TR 3 Temp Guage Capillary Tube Triumph 6
jlaird Water temp/oil pressure guage Spridgets 3
B TR2/3/3A ELECT TEMP GUAGE WIRING FOR TR-3? Triumph 3
AweMan TR2/3/3A TR-3 water temp guage Triumph 10
L Temp and Fuel Guage MG 10
Banjo Lucas gremlin in the temp guage MG 3
Baz Temp guage not working Spridgets 51
M Checking a temp guage Triumph 2
Tullamore Engine Temp Guage Spridgets 7
martx-5 Water Temp Guage Repair Triumph 2
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
MikeAH100M High Temp Engine Miss Austin Healey 2
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
shadowfever Water temp Spridgets 9
Govtslug TR6 Coolant Temp Q Triumph 4
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Rut Bugeye 1275 temp probe placement. Spridgets 8
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A temp gauge sealer Triumph 7
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A removing the temp gauge needle Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
JFS TR2/3/3A Radiator fan temp probe Triumph 3
JFS TR2/3/3A Temp Sensor Removal Triumph 6
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
Sopwith_Camel temp Jaguar 8
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
Got_All_4 TR2/3/3A Need a temp glass Triumph 11
