Electrics, fuel system, under bonnet temp.
why
I have been at the DIY British Car antics for over forty years. No formal training but actually enjoy the challenge of staring at the thing and with the little knowledge I have trying to figure it out and using a logical sequential plan isolating the true reason for the symptom. Having owned the '65 Healey 3000 for thirty years, I was well aware when I bought it that the bottom surface of the gas tank was full of warts made of some type of "weld-putty", including surrounding the drain bolt head.
A few months ago about 1 mile down hill from home it would start to cut out, by pumping on the throttle I was able to drive uphill and home. The thought was the steep down hill allowed the grunge in the gas tank to clog the intake. So $200 later I had installed a new gas tank, it seemed to run well for a week or so then same thing. Hmm, the old saying that in UK cars was you think is a fuel delivery issue is probably really electrics. Well what the H a coil is less than a gas tank, so on it went and no help. I then realized that the cutting out only started after a few minutes of driving. So under the bonnet heat may be the culprit. I recalled from many years ago such a thing on this forum when I was going through the same cutting out that it was a bad condenser. sure enough a new condenser and all is well. My rev counter was always a thousand or so too high once the engine warmed up, remembered on forum this being a possibly weak coil. Sure enough when I started to pay attention to rpm it was now correct, presumably from the new coil.
so in fact there is at times a reason for old sayings, in this case what you think is fuel delivery usually ends up electrics. Also replace not the most expensive thing first, but the cheapest.
Jay '65 3000
roscoe
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth". Sherlock was not wrong when he uttered this. The problem is that with these dang vehicles there is so much possible to be investigated that by the time you get to the improbable truth, all you can do is slap your forehead and wonder why you didn't go there first. My method is, like your lost keys always being in the last place you look, just look there first. The electrical being more likley than fuel is just because there are more points of gremlin entry than in the fuel system. Although gremlins first became known to aviators in the 1920s, they hit their peak during WW II. When the European theater calmed down after VE day there were more gremlins than there was opportunity to cause mayhem. Their guild was resourceful and soon made note of the growing British sports car popularity. The cars kept them so busy many of the young gremlins never touched an aircraft. Among the reclusive creatures the most popular given name is Lucas.
CanberraBJ8 fuel starving or electrics? Austin Healey 24
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
C Overdrive Electrics Austin Healey 8
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
Sarastro T-Series Modern Electrics for a TD MG 9
jlaird Spritenuts answer to electrics Spridgets 11
RobT Lucas Electrics Lovers Club Triumph 8
G Dumb question about electrics Triumph 22
Baz Auto Electrics Restoration & Tools 5
C Electrics MG 1
sultanoswing Sad Loss of MG Electrics Site MG 12
D Austin A35 engine electrics, esp generator British Motor Corp 6
sultanoswing Sodding electrics!! MG 11
philman my '76 fhc electrics work properly now? Triumph 1
mbrooks Great webpage on Lucas Electrics Austin Healey 3
KLUTZ Tempting.... to check electrics !!!!!! MG 4
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
