How to remove temp sensor at block?
christophe
Either the temp sensor should have a spacer placing it out from the block on a 6 cylinder and ours is missing, or i need a special socket. I purchased a set of O2 sensor sockets yesterday, but unfortunately it did not have a 5/8 unit in the kit.
So, am i missing something or is it time to bust out the dremel and make my own socket to remove the temp sensor? Needs to be slotted to go around the wire from the gauge. Im assuming that the temp sensor is like the ones used in original AC Cobras and has a bulb on the end of it that is filled with pressurized gas.
Thanks
Healey Nut
I took a 5/8 combination wrench , shortened it to clear the fan etc and cut a slot in the ring end wide enough to fit the capilliary line and bingo ur done . lots of rust buster or your fave release oil etc and patience .
Depending on your wrench you may have to grind material off the outer edge of the wrench to stop it binding on the cylinder head .
C
christophe
Good point. I think i have more junk wrenches than junk sockets, so that will probably work best. I have the radiator and waterpump off the car, so I should only need to cut a notch in the ring. Im going in!
Platinum
Hiya boyz!
Use a six-point wrench for the task, christophe. And the best penetrant BY FAR is a 50/50 mix of acetone and auto tranny fluid. Really.
C
christophe
Careful with the nut, it's soft and can round off easily. Also be extra careful with the bulb and tube. If they break and let the ether out, it gets expensive real quick.
Too late, it was already rounded off. Im down a wrench and it looks like a temp/oil pressure gauge. Is there anyway to cut the cable, leave the sensor in the block and then weld or solder the cable back together. Probably not, but im dumb enough to ask.
Healey Nut
That aint no cable is a capilliary line filled with alcohol if you cut it is toast and you need a rebuild..
Having said that do yourself a favour the nut is rounded , bite the bullet cut the capilliary line send the remains to Nisonger Instruments and get it all rebuilt cleaned refurbished and calibrated .
https://www.nisonger.com/index.htm
C
christophe
Oh, didnt know the entire cable was filled with gas. i thought it was just the fitting at the end. Told you I was dumb enough to ask...
I used nisonger a few years ago for some original style Smith's gauges. Ill give him a call once the damage is complete.
Keoke
That aint no cable is a capilliary line:----LOL! ! !
Healey Nut
A rebuild will set you back around 200$
bob hughes
On the other hand you could do what I did and grind up a small double ended spanner to fit but take care on how much is coming off the outer edges as you do not want to weaken the spanner too much. I have also ground down a spanner to fit the jet nut of the carbs as well as getting to them can be difficult
On balance, if I had a ring spanner spare I would have tried that first and the temperature sensor.
:cheers:
Bob
Billm
Best thing that I ever did for that cap tube is to go to Harbor Freight and for about $10 get the set of 6 point crowsfeet (sizes 3/8 thru 3/4).
That 5/8 crowfoot has taken off cap tube fittings that I couldn't get any other way.
REALLY good set to have!
BillM
Johnny
My AH was a total rust bucket with seized cylinders etc. and I was able to remove the bulb with llittle troubel. Just try spraying the nut and let sit overnight. then using the wrench, or vise grip if you can get it on gently tap it with a light hammer until it turns.
C
christophe
All gauges are being sent to Nisonger for rebuild. That nut was already molested/stripped and it wouldnt have mattered what i tried. The gauges looked pretty terrible once i removed them, so we just decided it best to send them all off to be calibrated.
John Turney
I cut a slot in a deep 6-point socket for r/r. You might as well make one. You'll need it to reinstall. I keep it in my box of "Healey tools".
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
