Temp gage from RB Midget
v8mgbal
Hello all, If my dual gage is dead can I use a temp gage from a 1500 car or is there another altenative, thanks in advance.
aeronca65t
Most of the 1500 cars use an electric gauge. You can use one but you will also need the sensor that screws into the head. Plus whatever wiring is needed.
In my (race) car, I bought a fully mechanical temp gauge from the local discount auto parts store (Autozone) and used that. It was under $20 USD. It did require that I look around for an adapter.....I eventually just made one (I have a lathe). But I've noticed that some of the gauges now sold come with a selection of adapters so you might be OK (I did this about 6 years ago).
JPSmit
Nial, I am not aware of 1500's ever using electric temp gauges. mine is a bulb and at 1976, I can't imagine British Leyland would change that, that close to the end of the run.
Alan, I'm almost certain you can swap one in.
dklawson
Can't say what the 1500 Midget would have used but BL did use electric temperature gauges on the 1500 Spitfire.
As Nial said, there is sometimes an adapter needed to fit the mechanical temperature gauge bulb to the Triumph engines (it's sometimes needed for clearance on A-series heads also). If you don't want to make your own, the adapter is available from Mini Mania. (Their part 11K2846, $14.95)
aeronca65t
J-P:
My '78 originally had an electric gauge (BL probably made the change to match the Spitfire 1500 setup).
Moss even lists the electric sensor (called a "transmitter) for it.
I much prefer mechanical gauges, so I was happy to make the swap.
Honestly, I really like the nifty little dual gauge that was referred to in the beginning of this, but they are hard to find (working) and not cheap to have repaired.
sparkydave
The 1500s didn't get the electric temp gauge until 1978, which is also when the oil pressure gauge was replaced with the idiot light. Glad I have a '77.
v8mgbal
v8mgbal
Thanks guys for the info. looks like a trip to the autozone to see what they have, $200.00+ dollars for a temp/press gage is just crazy.
dklawson
There are dual gauges that show up on eBay regularly. If the needles aren't sitting on the "left" side of the face... and horizontal, don't bid. They sell anywhere from $20 to $100 depending on the appetite of bidders and the gauge condition.
There is also a guy who periodically sells (professionally) reconditioned models on eBay. I think his price is around $140 and the pictures of his merchandise look good.
JPSmit
before you go to autozone, get Kim to walk you through changing the bulb - it doesn't sound hard.
also, while I'm sure you are correct that it isn't working, mine wasn't and it proved to be the needle touching the glass. You can test it with a boiling pot of water
dklawson
The information on replacing the expansion bulb of mechanical temperature gauges can be found at the following web site:
https://www.ply33.com/Repair/tempgauge
As long as the needle for the temperature portion of the gauge is still returning horizontal to the left, the method shown in the link will work. If the needle is resting at some other position it indicates that the internal bourdon tube is "stretched" and much more involved calibration and repair are indicated.
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
C TR 3 temp gage replacement Triumph 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
MikeAH100M High Temp Engine Miss Austin Healey 2
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
shadowfever Water temp Spridgets 9
Govtslug TR6 Coolant Temp Q Triumph 4
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Rut Bugeye 1275 temp probe placement. Spridgets 8
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A temp gauge sealer Triumph 7
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A removing the temp gauge needle Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
JFS TR2/3/3A Radiator fan temp probe Triumph 3
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
JFS TR2/3/3A Temp Sensor Removal Triumph 6
S TR4/4A Temp guage problem Triumph 5
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
Sopwith_Camel temp Jaguar 8
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
Got_All_4 TR2/3/3A Need a temp glass Triumph 11
B Temp gauge capillary tube Austin Healey 3
P Temp. Probe for 1275 with Bugeye Radiator? Spridgets 21
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
KVH TR4/4A Infrared Thermometer for Radiator Temp Triumph 6
Stewart MGB Temp sender issues MG 4
J Picture of temp gauge , Austin Mini British Motor Corp 2
Mink TR4/4A Temp gauge/sender question Triumph 15
N Temp Gauge No-Go Spridgets 5
A TR6 Temp gauge Triumph 11
C How to remove temp sensor at block? Austin Healey 16
