stripped threads on master cyl
Millrat
May have stripped the threads either on the master cyl or the flare nut on the clutch side on my 1962 Sprite. Is there a repair for the flare nut and pipe that doesn't involve replacing the whole pipe? I am willing to get a new MC as I have had nothing but pain with the one I have.
Thanks
Hot Wings
Thanks
It's not pretty but you can always splice on a new section of pipe (with a good end) using a compression fitting.
M
Millrat
That may be the way to go. Not pretty matches some of the rest of things under there.:smile: My main concern at this point is to get on the road.
macsprite
Is it a 7/8" bore Master with front drum brakes? I have one you can have for postage costs to get you out of trouble. Will need a good hone (or perhaps a re-sleeve) as it came out of my Bugeye that is getting disc brakes so upgrading to 3/4" bore. I probably have a usable clutch line as well if needed. Let me know by tomorrow noon if possible, as I am heading out of town for a few weeks, but can take with me and post Tuesday.
Cheers
Lew
Gerard
It will need to be heli-coiled. I can include that service if you want the unit rebuild and/or re-sleeved. I can also resize if you have a disc brake conversion with the wrong size MC. Just ask around here what you'll get back.
M
Millrat
7/8 bore. It is relatively new but it developed problems almost immediately. The main issue now is welter or not the threads for the clutch side connection are stripped. Need to take it back apart to check. So I can get it helicoil it to fix the thread issue?
Gerard
That would be the correct way to repair it.
M
Millrat
I am interested in the resleeve even though this is a fairly new unit (under 100 miles total). Purchased from VB about two years ago but the mechanic that installed it for me didn't understand the brakes on the car. We should have replaced all the brake hoses initially and then worked from there. Short version is that we put a lot of pressure on the new master cylinder. I would like to have a long lasting unit and if it can be accomplished with your resleeve that would work out well. Cost?
Gerard
Contact me offlist for details. Best to email me direct as well.
Jim_Gruber
Gerard just resleeved my master to 3/4" in brass. This is one I know will not corrode and begin leaking a short time down the road. Be sue and upgrade rear backing plates and wheel cylinders as well to match 3/4" MC.
M
Millrat
Mine is stock 7/8 with drum brakes. Just did all brake lining all the way round and replaced the rear bearings seals etc. The master cylinder was the first item I bought just before VB dropped the price from $300 down to the $130 or so they want for the same one now. If I had found this forum before I started I would have changed the brake lines out and not pushed the seals out of the MC trying to push brake fluid through a non existent hole. All this to say how beneficial the information here is:smile:.
M
Millrat
Took everything apart again and found that I hadn't done the damage I thought I had. Cleaned it all up really well and I think it will go back together now. Thanks for the replies.
Erik
S Stripped Threads Austin Healey 10
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
J Stripped threads engine block Triumph 7
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
davidk Stripped threads in oil pan front saddle block Triumph 12
M Block threads stripped torquing head Triumph 16
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Basil 7 Ways to remove stripped screws Restoration & Tools 2
B Stripped Thread in Gas Tank Austin Healey 26
G TR4/4A Well...another stripped trunnion Triumph 8
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
F New set of lug studs and stripped spines.... Triumph 12
P Stripped hood latch bolt Triumph 5
TRMark Being my own DPO, stripped front sealing block Triumph 6
L Stripped windshield frame screw hole Spridgets 6
K Painting a car not stripped to bare metal? Triumph 6
TRclassic3 stripped pan bolts Triumph 4
Lon_S Stripped a cylinder head nut Spridgets 7
DanNagy Spitfire Spitfire 4: Stripped Triumph 5
I Stripped screws in Bugeye windshield frame Spridgets 10
Tr3aguy Stripped and resprayed pics Triumph 4
Tr3aguy Stripped parts...yes Triumph 8
H Stripped headbolt Triumph 23
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
tinman58 TR2/3/3A stripped bolt TR3 Triumph 5
John Moore Big Milestone! Tub is stripped Spridgets 6
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
John Moore Front End Stripped and Questions Spridgets 20
R interal thread stripped on timing chain cover Spridgets 2
F GT6 GT6 differential mount stud stripped... Triumph 3
S Stripped bolt on timing cover Spridgets 17
Nunyas Stripped manifold bolts MG 4
drooartz I have a stripped Midget! Spridgets 16
B Paint Stripped..now Moss Motors or Victoria Brit? Spridgets 7
TexBug Stripped door hinge screw removal? Spridgets 4
T Question on primer after getting fenders stripped Triumph 16
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
Mark_Gibson Body Weight of a Stripped Down TR-2? Triumph 10
MattP Stripped Shifter MG 0
6 Stripped exhaust manifold stud Austin Healey 5
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
B Damaged threads in the gas tank Austin Healey 7
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
JimLaney Organizing threads into book? FORUM Navigation Questions 10
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
