started a rebuild of a 62 sprite. HELP required!
basefreek04
Im 17 and doing an exhibition project of rebuilding the engine on a sprite and i was wondering how should i approach taking out the engine. should i leave the transmission attached to the engine or unbolt it.
thanks,
Nelson
I have a 62 Sprite and I don't believe it is at all practical to consider removing the engine and not the tranny. There are only a few bolts holding the tranny in place so just remove them and pull the engine/tranny as a unit.
Nelson
Platinum
Yup!
Pull the engine/trans as a unit. It takes patience and planning, but MUCH easier than trying to do the two pieces separately. Especially when it comes time to stuff it all back together.
mccalebr
Agreed!
I'd also suggest taking off the bonnet (hood)...you'll need the room. If you plan to clean/test/repair the radiator, go ahead and remve it as well.
Ray
v8mgbal
also don't forget to drain the oil from the tranny! or have lots of rags handy.
texas_bugeye
Dont forget the 2 bolts on either side of the tunnel these are accesed from inside the car, you will need to remove the carpet from the sides of the tunnel to get to them.
seanb
Re: started a rebuild of a 62 sprite. HELP require
2nd on the draining the tranny fluid. when i took my engine/tranny out it crapped tranny oil all over the garage floor. i was doing good up until that point, lol. everything else people said is good info also. good luck
GB1
Don't forget the ground strap
Remove one motor mount from the engine (2 bilts) and one from the chassis (3 bolts).
tony barnhill
Great Pumpkin - R.I.P
& jack the rear end of the car up higher than the front end is jacked up!
jvandyke
I pulled mine earlier this year after heeding advice found here and did it with NO mistakes! Search, look at the manual and do it. You'll need to tilt the engine a lot so plan for that. Either a tilt mechanism on the hoist or something.
Pythias
I don't understand the "collective wisdom" of pulling the engine and tranny as a unit. I've done it both ways and see no appreciable difference in the amount of work involved ---except that it is easier to maneuver just the engine out than it is with the WHOLE DARN LENGTH of the assembly? AND you don't have to mess with draining the tranny or hooking up the drive shaft on re-install.
Billm
I agree with BillL that pulling the engine solo isn't hard at all but putting it back in is a bear!!! Put them in together but pulling them seperately is OK.
BillM
Golden_Swan
I have always pulled and installed the engine by itself. I just found it easier to align the clutch than to align the prop shaft.
jlaird
Prop shaft easy to install. Remove the four bolts at the differencal and pull it out. Tape the front ujoint straight. Stick it in when you have the engine and tranny all bolted up. Replace four bolts. Forget about the tape. One man job maybe 20 min.
jvandyke
Granted I've only done this once, but why disassemble the prop shaft at all? When I did it I couldn't get it apart easily so left it. Gearbox slides right off the shaft and on putting it back in, align the shaft into the gearbox as you go. Seemed to work easy for me that way but maybe I was just lucky?
GeeBee1
I like to keep my hands far away from that area when sliding one back in the tunnel. I have had a few bind on the transmission mount and then let loose abruptly. It is a matter of preference, but I also find it easier\safer with it removed.
B started a rebuild of a 62 sprite. HELP required Austin Healey 1
jaegzie Long time since I've been here but progress has started. Bigeye rebuild Spridgets 9
M Started rebuild-just a head gasket! MG 5
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
Tr3aguy TR2/3/3A Started a Car revival channel for the TR3 Triumph 12
T TR6 Car has always started without fail.....until now Triumph 10
Bayless Started adapting the datsun gearbox today Spridgets 46
J TR2/3/3A Finally getting started Triumph 20
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
G TR4/4A YAY! It started!!! Triumph 16
S TR2/3/3A Frustration has started but car wont. Triumph 4
HighAltitudeTR3 TR2/3/3A Just started burning some oil... Triumph 8
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
David Townsend Sprite Illustration Started Spridgets 31
David Townsend Sprite Illustration Started Austin Healey 7
David Townsend 100M Illustration Started Austin Healey 32
M_Pied_Lourd TR2/3/3A TS44836LO Resto Started Triumph 6
drooartz MGB-GT Conversion has started - splines to studs MG 51
Keith_M Bugeye Restoration Finally Started Spridgets 37
M My '65 suddenly started running bad today Spridgets 37
simon1966 Started to dig out the 100 Austin Healey 3
oxford New owner BN4. Work started . More questions. Austin Healey 13
T moved post from ZS 1500/started new Spridgets 4
I Help - can't get my bugeye started Spridgets 17
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
J Finally got my '56 started Triumph 3
R TR2/3/3A TR3A Finally started Triumph 6
Scott_Hower Hap started my head... Yay! Spridgets 13
rikiwho123 i started my 1300 Triumph 0
R MGA ITS ALIVE! MGA Started After Sitting 4 Years MG 1
I TR6 Getting a TR6 started again-where do I start? Triumph 9
M Project started-switching dash Spridgets 17
R MGB Getting started with the MGB - first questions MG 13
Nelson It started! Spridgets 5
J Rover engine that started as Buick? Rover / Land Rover 9
scoutll Car suddenly started running poorly Spridgets 17
doughairfield Trying to get my motor started Triumph 8
JPSmit It has started Spridgets 4
GregW Started working on the Healey again Austin Healey 12
pjsmetana Started instantly... without my choke! How? Why? Triumph 5
doughairfield TR4/4A HELP not able to get my TR4 started Triumph 104
6 got it started Triumph 4
M It started! Triumph 5
LastDeadLast Offically started my hardtop project - Question Triumph 5
Brosky Dash panel replacement page started Triumph 0
R '67 Midget engine started for first time in... Spridgets 9
JodyFKerr Finally getting started Austin Healey 1
