TR6 Getting a TR6 started again-where do I start?
ichthos
My 69 TR6 has been sitting for a year. I finally have it back together. I had the valves rebuilt (locally), I rebuilt the rocker assembly, and the carbs were rebuilt by Jeff at Paltech. I adjusted the valves and static timed the engine. My engine is hard to start, and I can't keep it running long enough to go work in the engine bay and adjust anything. Can you give me some ideas on what I need to check and the order in which I should do them? Any help is greatly appreciated.
Kevin
mrv8q
Just went through with this with my TR3; but only had the carbs and distributor rebuilt. It took about 7 minutes, from when I first tried to start it, to finally run long enough to then start syncing the carbs, etc. It would run for 1 second, then die; 3 seconds, then die; 5 seconds, etc.
I, like you, static timed, etc. If nothing obvious, perhaps try longer? Best of luck....
TR3driver
Great Pumpkin - R.I.P
Well, is the choke and fast idle cam working on both carbs?
If nothing else, this might be useful: https://www.harborfreight.com/12-volt-remote-starter-switch-35448.html
Oddly enough, a remote start switch was the very first automotive tool I made myself, back when I was only 16 or so. But mine was better, as it also had a toggle switch for the ignition (or ignition kill).
I
ichthos
Oops - I found my static timing was off some how. I adjusted it and the car starts right up. It looks like I have some adjustments here there still. I am going to take it on a test drive shortly. I have a few more questions.1) When carbs are rebuilt, I believe they are normally bench tested. Does this mean I need to make any adjustments to the carbs after I put them on? 2) My cams had some oxidation on them, and I could not get to them to remove the surface rust. Does this mean I will need to readjust the valves after running it a bit? 3)There is this bypass valve unique only on the 69 TR6. How do you know if it is working or affecting performance? Any help on any of these questions would greatly be appreciated.
Kevin
mrv8q
I found the answer to this question to be Yes! Not much, but some adjustments necessary....
TR3driver
Almost certainly.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] 2) My cams had some oxidation on them, and I could not get to them to remove the surface rust.
[/quote}Which cams are you talking about?
You had the head off to do the valves, right? That means you should retorque the head nuts, and reset the valves, after about 500 miles.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] 3)There is this bypass valve unique only on the 69 TR6. How do you know if it is working or affecting performance? [/QUOTE]That's the one with the adjustment screw, and external vacuum port, right? If so, you can use a Mity-Vac or similar to apply vacuum to the port. When the valve opens, the engine speed will increase (to roughly 2000-2500 rpm, according to the training notes). "Correct" adjustment is when the valve opens at just slightly more than idle vacuum.
I
ichthos
Thanks for the information on the head and valves. I took my car out for a test drive. When I try to accelerate, it makes a put put sort of sound and lacks power. I also have some white or grey smoke coming out the tail pipe. My wife said the smoke smells like gas to her. Is this a carb adjustment problem? I have not touched the carbs up to this point. I am always leary about touching something and making it worse.
Kevin
poolboy
Quote:
"There is this bypass valve unique only on the 69 TR6. How do you know if it is working or affecting performance?"
Unique to the 69 ? You must mean the Vacuum Control Valve, more or less under the front carb ?
poolboy
Pretty simple to test for function and adjustment, not that it needs to work in the first place. But if you disconnect the vacuum line attached to the retard module's nipple on the cockpit side of the dizzy and hold your finger over over the line, not the nipple, the idle speed will increase by about 200 rpms.
If it doesn't then either the valve is faulty or not adjusted properly OR the vacuum module on the dizzy is broken.
The module on the front side of the dizzy, btw, is for vacuum advance, and has the front carb as it's vacuum source.
TR6oldtimer TR6 My Mallard Blue '73 TR6 is getting there Triumph 15
M TR6 Getting my TR6 running again Triumph 3
hondo402000 TR6 TR6 Engine rebuild and getting uneasy feelings Triumph 36
Steve1970 TR6 tr6 getting "0091" reading from VAG scanner Triumph 1
R6MGS TR6 TR6 Short Circuit....this is getting irritating Triumph 23
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
