TR2/3/3A Finally started 17 year old rebuilt motor!
John_Progess
I posted earlier about our 17 year old rebuilt, never started motor for our 59 TR 3. It would just barely turn over with a new fresh battery. We did all the suggestions recommended here on this site and after 3 days of turning engine over with Marvel Mystery oil, cleaning all electrical contacts, warming engine and oil it still would just barely turn over and not try to start. So as a last resort I had the owner use the hand crank along with the battery and we got it to turnover fast enough to start. We let it run about 10 minutes at 2000 to 2500 rpm and had to stop it to fix a water leak. Trying to restart we had to use the hand crank again. After another 5 minutes we lost our electrical connection to the coil and it stopped. This time it started without the hand crank! It actually ran quite well with a temp of 185 deg F but an oil pressure of 100 lbs. I don't know if the gauge is correct but if it is, is 100 lbs oil pressure going to cause any problems? Next time we will try another gauge and check the pressure. All in all a successful day in the garage. Always nice to hear the engine run for the first time! Have a good day!
John
sp53
Right on, and yes get a new gauge and plumb it in. I have 2 old gauges that read high. I believe when the oil expands that little brass deal inside that after a while it gets easier and they read high, but I am not sure, yes get a new gauge.
CJD
Congrats...always exciting starting a new motor for the first time!
100 psi is a lot for a warm motor, but it is adjustable from the outside of the filter head. As Steve said, best to verify the actual pressure before making any adjustments. You may find it is actually much lower than 100.
When's the test drive?
TR3driver
Great Pumpkin - R.I.P
Also replace the oil with fresh oil, of a weight suitable to your climate. Heavy oil in a fresh engine can overwhelm the relief valve and cause the pressure to go high before the oil warms up.
High pressure is not necessarily an immediate problem, but does increase the chances of failures like leaks at the oil filter, or breaking the oil pump drive.
J TR2/3/3A Finally getting started Triumph 20
Keith_M Bugeye Restoration Finally Started Spridgets 37
J Finally got my '56 started Triumph 3
R TR2/3/3A TR3A Finally started Triumph 6
JodyFKerr Finally getting started Austin Healey 1
B Finally started work on the B MG 10
Basil Finally started back on my E-Type Jaguar 8
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
R GT6 Finally Finishing Triumph 19
