210 Tranny Case Mods started this evening
Jim_Gruber
This was supposed to get started 3 weeks ago but finally found a few minutes tonight to complete Step 1) for Case Preparation. Relieving Bell Hosing flange to clear oil pump cover.
Not too bad actually. I used a 2 1/2 or 3"cutting blade on a Hi-Tech Harbor Freight Cutoff Tool. 1) Marked what needed cut and used the edge of the Cutoff Tool to create a 1 /4" Relief in the side of the case. Gerard's Adapter Plate on Tranny housing 2) Marked Area to be cut 3) Post Cutting 4) My expensive HF Case Modification tool .
Went slow and it took about 1/2 Hour to complete. Probably would have been easier and quicker with a Grinding Wheel but no such luck in the Grinding/Cutting Tool Drawer in my Garage. Will do a little more smoothing with Dremel and Rotary Sanding wheel but essentially done. Now to see how my new Camera does with close ups. Not too bad on the closeups. new Canon T6, my Christmas present. Next Step removing the Spine along the top edge of the case to clear heater shelf already done, most challenging part is drilling 3 1 3/4" Holes in the top of the case, along with Angle Grinder and SawZall to modify the case so it fits under the heater Shelf. Pics to follow.
View attachment 51483 View attachment 51484View attachment 51485View attachment 51486
Boink
Bronze
Should work very nicely. Good job.
Jim_Gruber
Jim_Gruber
A bit more Dremel Work and Oil Pump Cover sits totally flush with top of Adapter Plate, no rocking, no movement, perfect.
nomad
Other than removing the rib on the trans I never had to make any further case mods to clear the heater shelf. The longer Datsun engine did require BFH to heater plenum.
BlueMax
[h=3]Jim, all I did was the oil pump relief and remove the casting spine, didn't do any other modes to the gear box in order to fit. I just don't know why you should have to make any other changes? Now I want say that the install was easy but I felt that the aggravation for esthetic made up for that... I used the Rivergate, not sure who's kit your using?[/h]
Jim_Gruber
Jim_Gruber
I'm using Gerard's Kit. Notch is cut where Center Spine is, finished, and then Aluminum Flashing and JB Weld close the case back up.
BlueMax
What a shame to have to butcher a gearbox to that extent then JB weld some aluminum plate in order to make it fit? That tells me that either it’s something wrong with the car or the rear transmission mount is sitting to high or manufactured incorrectly?
Boink
Bronze
I had the full indentation done (removing a fair bit) and even then it JUST fit in. Still, there are no structural issues with this approach. I can't see how it could be changed given the dimensions involved with the Datsun tranny.
Gerard
The issue has absolutely nothing to do with which kit is used, and the assumption is has anything to do with ill fitting parts or which kit is used is completely erroneous. The fact is, once in place, there is plenty of room for the gearbox, even if completely unmodified, including the rib. The issue has everything to do with getting the gearbox and engine installed simultaneously into the engine bay. The simple fact is that the distance between the bottom forward edge of the heater plenum and the bottom front edge of the oil pan, is one inch less than the distance from the top of the bell housing to the steering rack/crossmember. If the heater plenum isn't relieved by at least an inch, there isn't enough enough room to clear the bell housing once the oil pan makes contact with the steering rack crossmember. Some people modify the crossmember to something similarly done on the rubber bumper cars, where the cross bar is cut and a vee formed and welded to the top of the crossmember, This leaves plenty of room for the oil pan and crank pulley to clear. A large majority of owners are averse to doing any sheet metal modifications and prefer to modify a replaceable item rather than resort to a BFH. It's a personal choice. Alternatives are installing the gearbox separately first or installing the oil pan and crank pulley after the engine and gearbox are in the car, neither of which are great choices. The installation can can also be accomplished by just forcing everything in, but that will deform the heater plenum in the process. Notching the bell housing is not required, but one of the choices above is.
Boink
Bronze
... and I should have clarified that it was only about fitting the combo engine-transmission in that is the difficulty. I think there were only a few millimeters on the top side (to the heater plenum). I didn't want to beat the plenum up (or cut it). Once in, it all fits very nicely.
Jim_Gruber
Jim_Gruber
Gerard, Thanks for the explanation. A little more time to do some garage work this evening.
twas_brillig
We have two Rivergate Datsun kits installed, one behind a 948 cc engine (tight, but not impossible); t'other behind a 1275 and there is absolutely no way to fit the complete engine/transmission assembly in. The last couple of pull/installs, we've had to take the crankshaft pulley off and then try to reinstall where you can't (well, I couldn't) do a proper job of torquing it. The next time it has to come out, we'll be doing the 'cut the hole in the Datsun trans bellhousing' routine. An older, retired gentleman has been puttering away at building a 1275/5 speed for me using an original Paul Asgeirsson kit, and I'll be carving a hole in it once I finally receive it, as the chances of damaging other bits and pieces are just too great otherwise. Doug
nomad
Well, I've had two different installations in and out a couple of time's and things are tight but don't remember it being that bad. I may have fitted the trans mount after things were in place. That might make a difference. Last tear down was Datsun engine only with cross member modified but in a Midget. In a BE I would think its a piece of cake.
Kurt
Boink
Bronze
Mine is a 1275 and it was extremely tight to get in.
Jim_Gruber
Jim_Gruber
Ready to finish tranny mods in the AM. This setup I think will work.It's about 30 degrees in the Garage, Have not had dinner, and I'm exhausted after a long day. Not the conditions to do surgery on this 210 Tranny. And yes this is the spare 4 Speed bellhousing I picked up from Rivergate. Same Bellhousing as the 5 Speed. I would not want to do this surgery on the full transmission. View attachment 51509View attachment 51510Will get up and fire up the Heater in the garage and after about an hour it gets toasty warm. Temps up to 50 degrees and sunny tomorrow. Bugsy will get a little more exercise before the Cold and Snow come next week. For now I'll enjoy the remaining Drive Time.
Jim_Gruber
Jim_Gruber
Ready to finish tranny mods in the AM. This setup I think will work.It's about 30 degrees in the Garage, Have not had dinner, and I'm exhausted after a long day. Not the conditions to do surgery on this 210 Tranny. And yes this is the spare 4 Speed bellhousing I picked up from Rivergate. Same Bellhousing as the 5 Speed. I would not want to do this surgery on the full transmission. Center Rib and the big Flange need to be removed, Hole Saw and connect the 3 holes with an Angle Grinder and my trusty SawZallView attachment 51509View attachment 51510Will get up and fire up the Heater in the garage and after about an hour it gets toasty warm. Temps up to 50 degrees and sunny tomorrow. Bugsy will get a little more exercise before the Cold and Snow come next week. For now I'll enjoy the remaining Drive Time.
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Rut 210 tranny Spridgets 10
lbc_newbie Datsun 210 tranny....ventilation or missing screw? Spridgets 2
lbc_newbie 210 tranny starter cover Spridgets 10
Gundy Looking for a Datsun 210 tranny Spridgets 16
lbc_newbie Gear oil type for 210 4 speed tranny.... Spridgets 3
mrsprite Who needs a Datsun 210 tranny? Spridgets 12
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
Rut 1275, 210 5 speed, adapter kit, 3.90 Spridgets 6
bugedd Datsun 210 Trans Question Spridgets 9
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
RickB Datsun 210 with manual transmission $500 Spridgets 0
RickB OT - NMC - looking for a radiator for my wife's 210 Spridgets 8
C 1981 Datsun 210 for $900 Spridgets 6
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
Gerard Release bearing return spring for 210 gearbox Spridgets 3
Rut 210 for sale Spridgets 1
RickB Thought I saw a 210 - but it was just a B Spridgets 6
BlueMax 210 5 speed Gearbox Spridgets 0
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
Jim_Gruber 210 5 Speed listed on Bugeye Parts Forum Spridgets 1
bugedd Datsun 210 trans question Spridgets 33
RickB Datsun 210 on Craigslist Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 0
RickB Datsun 210 motor and 5 speed Spridgets 6
M T9 or Datsun 210? Spridgets 15
B How to identify a Datsun 210 5-speed transmission Spridgets 1
B Datsun 210 donor Spridgets 2
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
B Dat 210 w/5-speed in Seattle area [NFI] Spridgets 4
G 210 5 speed parts problems Spridgets 3
G What's the slave cylinder part # for 210 swap? Spridgets 1
G Datsun 210 5 speed disassembly Spridgets 23
B Datsun 210 trans value? Spridgets 32
G Found a 210 for $200 sitting in a field Spridgets 9
G Found a 210 wagon Spridgets 9
T Shift Levers for Datsun 210 5 speeds???? Spridgets 34
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
RickB Datsun 210 w/5sp Seattle Craigslist [nfi] Spridgets 0
