moved post from ZS 1500/started new
Tipsy
While working on my 76 1500 midget because of some starting problems I decided to change my plugs. While I was changing my plugs I figured I would do a compression test. My dry results revealed #1@155, #2@120, #3@125 and #4@125.
I asked the question: Is one high cylinder an indication of a bad exhaust valve or are 2, 3 and 4 low? I can't find any specs that say what compression should be? Does anyone else know on a 1500?
Morris responded as follows:
I'd say #155 is about right. Low compression could be a whole slew of things. I would run some Sea Foam through the intake and see if that doesn't bring your numbers up. After that, you can squirt oil into each plug hole and see if that does not bring your numbers up. If your compression comes up after squirting oil, the problem is likely your rings. If not It's likely your valves... or a blown head gasket, which in my experience is super common on 1500s.
And so I did not yet do the Seafoam but I did 3 squirts of 30w oil in each cylinder for a wet test and the results were as follows:
#1@195, #2@190, #3@210 and #4@170
Anybody have any thoughts now?
Thanks!
Jeff
Morris
If you have black sooty plugs, all that carbon and soot can keep your valves and rings from sealing too. That is why I suggested SeaFoam.
While 125 isn't great, it's not an emergency. I would focus on getting your carb working right, then worry about your compression. Otherwise, you could end up having to make the same repair over and over again. I still think your problem is float related. Either, your float level is too high, trash is preventing your float from closing, or your fuel pump is too powerful and it is pushing your float open when it is closed (this is a common problem). The common solution to the last problem I mentioned is to install an inline fuel pressure regulator.
T
Tipsy
Hoping to get to the seafoam soon. Never done it with this type of carb before. Is it done the same as others or something different?
Thanks!
Jeff
RichBall
Thanks!
Jeff
I would ask what you concider three squirts? Remember that anything you add to the cylinder will decrease it's volume and increase you compresion. If three squirts were long pulls on a triger type oil can that may be too much. Just a thought about why your number came up so much.
steveg Indirect interest xpost: Laycock moved to El Cajon, CA Austin Healey 5
G Moved to Surf City NC Spridgets 8
E Clutch issue with 1973 Midget, moved from MG board Spridgets 16
Marvin Gruber Need Car moved from West coast to ALA Triumph 8
M Need Bugeye moved in SW FL to SC Spridgets 4
NickMorgan Pedro moved to Portugal? Triumph 6
philman Wedge the ants moved in to my tr7 fhc Triumph 7
JPSmit Moved - now the questions Spridgets 2
Randy Forbes It moved under its own power... Austin Healey 7
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
P TR2/3/3A Block treatment post cleaning Triumph 17
jlaird MGB Don't post like I did 10 years ago. MG 7
EWD TR6 74 TR6 - “ A Post Seal” Triumph 0
jlaird MGB Follow up to my bad post on prewar MGs MG 4
Gliderman8 Editing a post FORUM Navigation Questions 6
F General Tech trouble with editing post Triumph 2
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
B TR6 New Member, first post Triumph 1
S TR4/4A B post to sill Triumph 5
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jim_Stevens For Sale Post-60K LH door Triumph Classifieds 2
R General Tech How to attach pic's to a post? Triumph 1
R Adding attachments to your Post FORUM Navigation Questions 1
tahoe healey past post about sholder belt foam Austin Healey 2
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
D Test image post FORUM Navigation Questions 1
ckeithjordan TR2/3/3A Apple Hydraulics vs White Post Restoration Triumph 13
M battery helmet stuck on post help Austin Healey 8
T Trouble inserting pictures to post FORUM Navigation Questions 2
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
PeterK TR4/4A From a VTR post on Facebook. Herman has passed. Triumph 16
Lin Post in float bowl came loose Austin Healey 6
NutmegCT battery post connectors Restoration & Tools 6
S TR2/3/3A The door and B post hardware Triumph 3
R TR2/3/3A "B" post Triumph 7
Tinkerman TR2/3/3A 1960 3A post 60,000 top installation Triumph 6
Rut 2 post lifts Spridgets 18
Randy Forbes HMN Blog post about AHS 3610.... Austin Healey 6
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Got_All_4 TR2/3/3A Need Pic of a Post TS60000 Occasional seat Please Triumph 5
T How to post photos? Spridgets 6
J TR4/4A Answer to my post "help with tr4 transmission disassembly". Triumph 9
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
CJD TR2/3/3A Screw Post Coils Triumph 6
S This internet article/post made me laugh... Austin Healey 5
AUSMHLY Can't post photos, why? Austin Healey 0
