Clutch issue with 1973 Midget, moved from MG board
HAN8L1965
Welcome aboard, I am sure after a few posts this group will have you up and running in no time. They have already sent you down a good path.
Mark
E
earlgrey
Thanks Mark. I hope I can get it running. Project two will be fixing the wipers. I think actually being able to shift is a good place to start though.
Ok, I started getting the mouse nests from the winter out of the trunk and the battery compartment. darn rodents.
I will let you know how it goes tomorrow.
Ari
jvandyke
If it is the slave, you can rebuild them from below, leaving it in place (assuming it is similar the one in my '63, which it should be). Very simple to do, three parts or so. Bleeding all the air out is the really trying part. Good thing you have kids, good for pumping pedals during bleeding (EZ bleed or not, it seems old fashioned bleeding is always part of the process). I put a "speed bleeder" type bleed nipple on mine which makes it easier for a one man job (my kids are now wise to the bleeding routine and run when they see me with brake fluid in my hand). You're probably wasting your time bleeding it before you rebuild or replace the slave but then again, I'd probably try it too, while I waited for a rebuild kit to arrive in the mail.
Welcome.
'73 is a good year, ain't no '63 but good none the less.
E
earlgrey
The whole rebuilding from below thing has me nervous. I have never done that before. I purchased a good jack and some stands to put the car on. When jacking up the Midget for a tire there is the provided lift point for the standard MG jack. Where is the safest place to jack up the Midget with a standard jack and should I raise up the rear end or the front for best access to the Slave. I recognize the car is not that big and it may not matter. But I figure there is a preference.
Thanks
Ari
JPSmit
Rebuilding is easy - we can talk you through that. When you say proper jack, I presume you mean a floor jack. I either jack against a suspension component or under the cross beam at the front under the engine. At the back, either the axle, or the differential or in a pinch (and with a piece of 2X4) where the front springs attach to the floor. NEVER jack on the floor sheet metal as it will buckle.
You want to block the rear wheels and jack up the front. The slave is attached to the side of the transmission. For that kind of work, I actually prefer the car completely in the air on four jackstands, then there is lots of room to move and no danger of the car rolling.
Coming back to the rebuild, you are talking about replacing rubber seals - so, once you have it apart, it's all about cleanliness and getting it back in the right order. My experience is 1500 Midgets, I can't recall how similar they are. If you buy the slave rebuild kit, but the master as well and and new hose do it all, - it's not expensive and then you don't have to worry.
jvandyke
Re: Clutch issue with 1973 Midget, moved from MG b
I usually jack under the differential with a small block of wood between, raise it high and put jack stands under the the axles. Front I just from the cross member, hunk of wood again to distribute the weight. Block the opposite axle as you jack of course. Axle stands there too, all four corners nice and high (sometimes better to do it in stages so one end isn't so high up that the other is too low to jack) and plenty of room to crawl under to do the rebuild.
As I recall, the slave rebuild consists of removing the pin to detach the slave pushrod from the fork. Take off dust boot, take out C clip, extract rod, piston, remove rubber seal, replace with new, reassemble and bleed.
Really very easy
Items 35/38/39, those parts (see link). Rebuild kit is $9. I wouldn't touch the master at all unless it is suspect. Those are a bit of pain.
Moss Diagram
davester
I've never seen a leaking slave cylinder that didn't have a corroded bore. At the very minimum you need to hone it after doing ivandike's steps to get rid of the corrosion pits and smooth out the bore. Otherwise it'll leak again.
jvandyke
I don't remember honing my slave, swiping with my finger and looking closely it seemed decent and must be as it doesn't leak. Although, now that you mention it, it could still be letting pressure pass internally and not getting good clutch effect and I do have a bit of an issue with good clutch. Is that a plausible scenario? Slave seal doesn't quite hold up the pressure so you don't get good travel? Hmmm maybe just swapping in a new is better in the end anyway. I'm becoming a convert. Now, on my master cylinder I wasted a lot of time and trouble trying to rebuild it when it's bore was too far gone (pitted and chewing up seals) that I did hone out (carefully). Still a $9 rebuild kit vs. a $300 master.....(or a $60 slave). This is becoming a thread hijack, sorry.
E
earlgrey
No worries. All this is great info.
Will let you know how it goes.
Thanks!
JPSmit
and that's my point, everything rebuilt fine on my car except the clutch master - but, to my mind, the low cost of the kits always makes it worth a try.
jvandyke
I agree, worth a try. I did find a rebuildable master for $25 so I still avoided the $300.
Jim_Gruber
I ended up replacing slave and master with new and 10 years later knock on wood still working, master leaks a tiny bit of fluid but that's part of owning a LBC. You will find that getting the bolt to the top hole on the slave is next to impossible with the engine in the car. One solution the racer's use is to take a grind off the edge of the mounting ear/ cut a slot in the mounting ear such that you can have the top bolt partly started. Then slide the slave into place, mounting ear slides in sideways under top bolt, and insert bottom bolt. Tighten up both and you are home free.
jlaird
Or mount the slave as you are putting the engine and trany back in.
E
earlgrey
Well.... OK so there was a leak in the system. In fact both the slave and the Master. It was to much for just me, so I took it in to a good MG mechanic and he replaced both. He showed me the parts from the old slave and someone previous to my ownership had done a butcher job welding the rod. It was a mess.
But the car now runs great (for now...) and I took it out, dropped the top and turned heads. Everyone loves the Midget. Lots of people leaning out windows asking "what is that?!"
Now I can move on to replacing that reverse lamp (which arrived today from victoria british). That I know I can do.
I am also saving up for a new clutch.... just to be safe.
Thanks guys!
If anyone is in or will be in PA please drop me a line.
Cheers
Ari
JPSmit
earlgrey said:
Now I can move on to replacing that reverse lamp (which arrived today from victoria british). That I know I can do.Cheers
Ari
Great news! It is wonderful the attention you get, women and children LOVE these cars.
The reason I quoted above is this - post needs here first - I have reverse lights (at least lenses) that you could have had for free. We're a pretty resourceful bunch and we like to share :cheers:
E
earlgrey
aha! well next time I will make sure to ask :smile:
Cheers
Ari
E T-Series 1973 MG Midget, Where to Start with a clutch issue MG 8
N Spitfire Clutch issue Triumph 7
J "Smitty" 5 Speed Clutch Issue Austin Healey 17
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
K TR4/4A Need help with clutch issue... Triumph 2
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
K TR2/3/3A Resolving my Clutch slave issue.... Triumph 3
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
J Found My Clutch Issue Austin Healey 3
S Clutch Disengagement Issue Triumph 20
pakiwi Clutch / Gearbox issue Spridgets 6
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
DMShuman TR5/TR250 TR 250 issue with Clutch pedal Triumph 4
M Shifting Issue: Clutch Question Spridgets 4
Brosky TR6 Corrected post regarding knocking TR6/Clutch issue Triumph 4
BritBox Yet another TR clutch issue Triumph 24
T T-Series Clutch issue MG 14
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
