SteveBones
OK, on to the next and hopefully last issue before I can finally take the TR3A for a drive.
The problem is with the clutch. The car has not been running for 10 plus years. I replaced and rebuilt all the clutch hydraulic items recently, and also adjusted the slave cylinder pushrod per the manual.
Even though I can feel and verified movement at the slave cylinder when pressing in the clutch pedal, the car will not go into gear when the engine is running. I can shift into all gears when the engine is not running. It is an original gearbox. With the engine running and the clutch pedal all the way engaged, first gear will grind, and 2nd or 3rd will just not go in.
Any suggestions on how to resolve this? I do know and have taken the transmission out of a TR in the past to replace the clutch. I am prepared to do this if needed. I am hopeful that there is an alternative.
Thanks in advance for your help on this. I will be able to start working on this on Sunday.
Steve
Steve
