TR2/3/3A Resolving my Clutch slave issue....
karls59tr
Bronze
I've cut out the rusty drivers side floor board to replace it. This also gave me an exposed view of the clutch slave cylinder. It seems that I had installed it on the wrong side of the bracket if I was going for the TR3 application. I installed it in the correct location for a TR3. I have a TR6 gearbox in my car. When I go to adjust the pushrod is the clutch shaft Lever pulled "towards" the gearbox when setting the rod length? Also because it's a TR6 box what size gap should I use when turning the pushrod into the clevis as the TR3 and TR6 each have a different spec?
TR3driver
Great Pumpkin - R.I.P
What spec did you find for the TR6? Are you still using the TR3 return spring?
K
karls59tr
Bronze
I was driving with the return spring off because that seemed to be the only way I could get the clutch to work, however I did hear a noise when the clutch pedal was up so I believe the release bearing was still riding on the pressure plate to some degree (hope I didn't do too much damage!)
I'm waiting for a new return spring and pushrod to come in from Moss as I had shortened the old pushrod in my futile attempts to get the setup to work.
I have a TR6 box but am using a TR3 clutch/pressure plate/release bearing and slave cylinder. Should I just use the adjustment method as described in the TR3 manual? Can't recall it offhand?
I think the adjustment for the TR6 was 0.06" but the TR6 slave dosn't use the external return spring,correct?
TR3driver
AFAIK there is no spec on the TR6, because it doesn't have that adjustment. .060" should work OK (that's about what I run), but it would probably be safer to stick with the .100" given in the last edition of Practical Hints. I think the larger value is just to give more margin (for clutch wear) before it has to be adjusted again, but that's just a WAG. The adjustment method given in the workshop manual is probably the easiest.
If you stick with the TR3 mounting pattern (bracket on the back of the transmission flange, slave cylinder on the front of the bracket) then you probably will need to shorten the pushrod. I found that I also needed a little tab to stretch the spring farther, to get the piston to reliably return all the way but YMMV.
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
