Smog/Emissions question
111
I do not want to wear out my welcome, but this car is completely foreign to me in more ways than one. I also attempted to search for smog pump related threads without much success.
The previous owner seems to have disconnected the smog pump system to a certain extent, yet left the belt on the pump. One hose coming out of the pump is sealed off, other parts are missing. Heck it looks like this has a different carb on it, and it has headers instead of stock exhaust. That big canister under the carb is also missing, which I think was some type of a cat? Since mine is obviously not working as originally installed, why would the belt still be left on it?
Anyway, what is entailed in removing the emissions/smog system completely, and is there anything I must watch out for so as to not make the car run poorly?
PAUL161
This is a pump on a 72. I'm not sure if it is hooked up the same as on a late model, but I don't think they changed this old style system on the MGBs. All it does is pump air into the exhaust ports to help in burning unburned fuel in the exhaust. The power loss by running the pump is negligible and without instruments hooked up to the engine, you'll never notice any difference in power with it hooked up or not. If you remove it, you must plug the manifold connection holes in the head. If the pump is not hooked up and you have no plans to, then I'd take it off the engine and forget it. Don't trash it, as someone who is doing a concourse restoration would more than likely buy it from you. Here's a photo of the one on the wifes car. PJ
111
Nice looking engine bay. Needless to say I will not throw out any parts because someone will always want/need them. It just does not make any sense to leave part of it connected unless there would be harm in removing it. I just don't get why the previous owner left a belt on it considering the modifications he did like adding headers.
PAUL161
I would have to say that there are probably more MGBs running around with the pumps off than with them on! PJ
JerryL
Howdy, I think first step would be Check your state regs as if required to have it. While in CA to get it smogged I needed the complete system, had almost none of it, PITA Found a donor system off a BGT, rusted pump but soaked with oil & got it turning, Did not like the idea of open ports into the head so I welded up the tube ends going into the head, all they wanted to see was it there did not have to change the output.
After leaving CA I stripped it all off, Even in NC, in theroy you are supposed to have what came stock on the smog system. No one really knows these cars, so the best bet is to remove things that are obvious something is missing.
Remove the fan from the water pump and take off the extra pully for the belt (they are seperate and all bolt together like a sandwich) and Moss motors(others too I assume) sells a ROW thermostat housing in aluminim to replace the cast iron one with the big honking bracket hanging out for god and everyone to say, What went there??
I had also gutted the Cat years earlier, SAVE IT ALL, you never know when you may need it with GVMT Regs.
I like the car much better with out it, also added an alloy valve cover to get rid of a vent tube that looked odd and it stopped the oil leaks.
Currently running headder and the downdraft Webber with K&N, I bet 200 lbs cme out of the car along with the system.
Regards
OH and Paul that is simply a stunning example of the under hood!!
No worries....happens to the best of us....just a mild case of CRS. :smile: LoL
M Smog pump and alternator brackets Spridgets 0
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
Y Passing the smog test MG 17
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
C TR6 Need to pass CA smog, Los Angeles Triumph 4
B MGB Calif. smog questions MG 29
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
J MGB Smog test fail MG 11
J Wedge Modified TR-8 in California...I need help to pass smog...HELP!!!! Triumph 25
Bob Claffie MGB MGB smog control ???? MG 12
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
P E Type V12 PCV & Smog systems Jaguar 8
SCguy Wedge My TR8 failed CA smog! Triumph 9
pakiwi Removing Head with Smog Equipment Spridgets 8
B New Proposed California Smog Legislation Triumph 5
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
neilh passed CA Smog - now it won't idle! Spridgets 3
ncbugeye Smog oil-filler cap Spridgets 3
SCguy Wedge My new TR8 and CA Smog [Latest picture] Triumph 26
S Smog? Mine's a '76? Story of My Life... Triumph 9
G smog equipment MG 29
drooartz Smog head 1275 question Spridgets 33
skinsgamer Passing Cali smog Spridgets 6
G Is there a procedure to remove the smog equipment? Spridgets 1
H Spitfire My Spitfire declared smog exempt! Triumph 0
6 MGB-GT De-smog'in the 71 B GT help? MG 25
S Smog Equipment Removal MG 7
77_MG_Midget Issues passing SMOG testing Spridgets 2
Nunyas Smog Pumps... the Op check... MG 2
TNMGB What smog stuff am I missing here? MG 13
MattP Smog pump question MG 3
Bret D-Day in Poway - Smog Test! MG 9
A Removal of the Smog Equipment MG 39
RobSelina Removing all smog equipment and my heater Spridgets 13
M Removing smog devices MG 5
MrBlueSky Wedge tr8 air/smog pump?????? Triumph 6
Bret Smog Test Round #2 - A Happy Day! MG 0
Bret Smog test: Round #1 MG 20
X how to beat the smog test Restoration & Tools 4
M Spitfire Kalifornia smog and the Spitfire Triumph 18
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
Celtic 77 MGB Emissions controls. MG 4
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
G Spitfire Emissions problems Triumph 3
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
brgrmyster GT6 1968 GT6 MK. 1 original emissions lines Triumph 0
B MGB 79 MGB - restoring emissions controls MG 5
B MGB Trying to restore emissions controls on 79 MGB MG 0
