MGB Smog test fail
Jerry
1978 MGB with a rebuilt engine and about 400 miles on it will not pass smog after 3 tests. The carb is pretty lean but the CO2 still does not pass. We can tell it is lean based on the lack of acceleration and pinging. IE: the acceleration was there prior to adjusting and taking it to smog. The smog pump worked when we rebuilt the engine but since its job is pumping outside air into the exhaust prior to the catalytic convertor, how do I know it is pumping enough air? Is there a way to increase the air that is pumped into the exhaust, ie, use the dilutional effect?
Last question, the car has its original catalytic converter. We know it works, because it gets really hot. But would there be an advantage in adding another one to the car to get the smog test passed?
Any other ideas?
Jerry
PS: California car
Sarastro
Back in that era, as I remember, it was almost impossible to pass a smog test unless the carb mixture was set up with the car hooked to the emission tester. You adjusted the mixture for minimum emissions. It might be just that simple.
For one thing, having the mixture as lean as possible does not mean you will minimize emissions. The catalytic converter works best in a narrow range close to the stoichiometric air/fuel ratio (14.7); one way, you get more NOx and the other, more CO and I forget what else. The sweet spot is rather narrow.
As for the catalytic converter, I'm not sure that its getting hot means it's necessarily working, although I realize it has to be hot to work. I'm no expert on this, but I always assumed it gets hot just because of the heat of the exhaust. If there are other phenomena that heat it, I'm not aware of that.
People who know more about this than me can tell from the test results if the problem is simply adjustment or the cat converter, air pump, or whatever. So, I think that if you take it to a shop that specializes in this, they should be able to diagnose it.
Deleted member 8987
https://www.aircare.ca/repinfo-ere-causes-co.php
Above gives some pointers.
When I used to have to get cars through this process, I'd start with several things.
First, remove the air cleaner element and place it in the boot (unless they look in the air cleaner housing).
This STOPS any restrictions causing high CO2.
Next, unless they do a visual, I'd remove the PCV hose from the valve cover and let it suck clean air.
If that isn't possible, due to peeking, change the oil and filter. Contaminated oil will do that with a PCV system.
Then, if this is an idle test, lean out the idle mixture.
If high speed, drop the float level a bit or if your car can limit load mixture, set that lower.
Do you have the importation paperwork?
I do remember the readings were hard and fast as far as meeting specific levels...except British cars, which IF you had the original paperwork that stated what your car's readings were, that it was accepted for sale with, THOSE were the limits, not the book.
Dave
J
Jerry
Car has been passed through 2-4 owners so the original paperwork is gone. The guy that did the test did inspect, but really has not much idea what is stock. I know the removal of the air cleaner makes it lean out because we took the car for a test drive without the air cleaner. It was lean, no accelleration at all. In California, the test is run at 15 mph and 25mph.
I keep thinking the CAT is no longer working as it should . An expensive part.
Deleted member 8987
Air cleaner better not lean it out that much if removed. Means you've adjusted the carb(s) with it on and it's very restricted.
But...we have a problem.
Bear with me, as it's been a LONG time since I did this in a shop.
But:
CO2 SHOULD be high, the higher the better. Higher COP2 readings tell you you have good combustion.
Low C02 shows possible misfires. Higher the CO2, the more efficiently the engine is operating.
So, CO2 is LOW? Only way it won't "pass". All sorts of things, including dilution from exhaust leaks.
Confirm.
Dave
J
Jerry
15mph o2 3.1
25mph O2 3.6
I will correct my fail above, it failed the CO measurement. IE: at 15mph max is 1.41 and the car was 2.03 same fail at 25mph.
Jerry
Deleted member 8987
Ah. Okay, CO, not CO2.
Read up on the link I provided earlier: https://www.aircare.ca/repinfo-ere-causes-co.php
Fuel system too rich. Fuel pressure too high. Contaminated oil. Charcoal cannister saturated. Those kind of things.
Zenith carb, right?
Diaphragm leaking, causing slow lift and rich mixture?
If your HC's are good, really need to look at carb internals, diaphragm, cannister, polluted crankcase (and that happens from short trips).
Dave
JPSmit
BTW, I have a Harley Davidson take off muffler - I am 95% certain it has a cat built in - cost me $25, often they are free.
smaceng
Without having a history on the CAT, I would replace that, and as suggested above, need to tune the mixture and timing with the exhaust being tested. You are not that far from what you need. Scott in CA
PAUL161
Any other ideas?
Jerry
PS: California car
Move to Oklahoma, we don't have any smog tests! Actually, we don't have ANY vehicle inspections. :encouragement: PJ
AngliaGT
In California,you have to have a California only cat.
I was surprised to hear that when our '94 Dakota needed a new one.
- Doug
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
Y Passing the smog test MG 17
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
Bret D-Day in Poway - Smog Test! MG 9
Bret Smog Test Round #2 - A Happy Day! MG 0
Bret Smog test: Round #1 MG 20
X how to beat the smog test Restoration & Tools 4
M Smog pump and alternator brackets Spridgets 0
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
C TR6 Need to pass CA smog, Los Angeles Triumph 4
B MGB Calif. smog questions MG 29
J Wedge Modified TR-8 in California...I need help to pass smog...HELP!!!! Triumph 25
Bob Claffie MGB MGB smog control ???? MG 12
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
P E Type V12 PCV & Smog systems Jaguar 8
1 Smog/Emissions question MG 8
SCguy Wedge My TR8 failed CA smog! Triumph 9
pakiwi Removing Head with Smog Equipment Spridgets 8
B New Proposed California Smog Legislation Triumph 5
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
neilh passed CA Smog - now it won't idle! Spridgets 3
ncbugeye Smog oil-filler cap Spridgets 3
SCguy Wedge My new TR8 and CA Smog [Latest picture] Triumph 26
S Smog? Mine's a '76? Story of My Life... Triumph 9
G smog equipment MG 29
drooartz Smog head 1275 question Spridgets 33
skinsgamer Passing Cali smog Spridgets 6
G Is there a procedure to remove the smog equipment? Spridgets 1
H Spitfire My Spitfire declared smog exempt! Triumph 0
6 MGB-GT De-smog'in the 71 B GT help? MG 25
S Smog Equipment Removal MG 7
77_MG_Midget Issues passing SMOG testing Spridgets 2
Nunyas Smog Pumps... the Op check... MG 2
TNMGB What smog stuff am I missing here? MG 13
MattP Smog pump question MG 3
A Removal of the Smog Equipment MG 39
RobSelina Removing all smog equipment and my heater Spridgets 13
M Removing smog devices MG 5
MrBlueSky Wedge tr8 air/smog pump?????? Triumph 6
M Spitfire Kalifornia smog and the Spitfire Triumph 18
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
