MGB-GT De-smog'in the 71 B GT help?
647F
I am in the process of reinstalling the engine into the BGT and i want to rid myself of as much of the annoying smog stuff as possible...has anyone else done this, and what can i remove?
i want to simple again...
tony barnhill
Great Pumpkin - R.I.P
Yep, many times - & you can remove everything!
Platinum
err... EVERYTHING?!?!?
...ewwwww!!! /ubbthreads/images/graemlins/devilgrin.gif
647F
[ QUOTE ]
[/ QUOTE ]
so i can pull off the valves, the crap over the spark plugs, how about all the plumbing on the intake (i dont know what i can and can't pull)
Does anyone have a picture of a non-smog engine bay i can work from?
tony barnhill
EVERYTHING!
About the only thing I might leave is the carbon cannister & return fuel line....but I also removed them from Jerri's GT!
Platinum
I've a photo of a "non-smog" engine bay but it's a 1964... not "quite" what you meant, I'm sure /ubbthreads/images/graemlins/wink.gif
As Tony says: It can ALL be removed. Plug the holes and press on.
Platinum
I've found brass 1/4" pipe plugs in most of the ones I've seen. I don't think they're the same thread as the head, but that's what people do.
Do NOT throw anything removed away.
These parts have value.
Clean them, label them, and baggie/box them for future use/sale.
tony barnhill
Absolutely true - & if you don't want to store them, send them my way...I collect them
647F
[ QUOTE ]
[/ QUOTE ]
guess i should go clean out the dumpster... /ubbthreads/images/graemlins/eek.gif
Platinum
[ QUOTE ]
they are not 1/4 pipe (or atleast not what i think)
[/ QUOTE ]
They are NOT 1/4" pipe, they're BSP thread... but about every head I've ever worked on wot's had the ports blocked have had brass 1/4" pipe plugs forced into 'em. Sorry if that was ambiguous.
tony barnhill
I've got all kinds of smog stuff on the shelf....just waiting....if anybody wants to send me theirs, I'll pay the postage to me
Platinum
Cornerin' the market, eh? /ubbthreads/images/graemlins/lol.gif
Cagey. Veery cagey.
AlanT
The size of the air injection hole is 7/16-20. (7/16 fine) I use countersunk allen screws made for securing pulleys to shafts. You can find them at GOOD hardware stores , but I don't think there are any left in the Atlanta area.
I have a thirty gallon drum almost full of air pumps and such. Still waiting for them to get valuable.
Alan T
Platinum
ahhh... couldn't recall that. Thought I'd gone on a hunt for the "correct" plugs for one, back 20 years ago... somehow I remember'd it was BSP. Thanks Alan. NOW it gets filed in the Bentley book!
647F
when i first got my B, it had just passed into the no smog reguirement, i had some guy offer me like 150 for the smog pump, as it still worked (i though he was wierd)...
The emission control equipment have value in metroploitan areas or state where mandatory emissions inspections are carried out. (ie - Chicago, St.Louis, California)
Some of these cars have not been grandfathered into a "no test" classification.
Nunyas
/ubbthreads/images/graemlins/iagree.gif MGB smog pumps have value in Kali.... especially for the '76 through '80 model years. For the time being, all cars '76 and newer are required to have smog testing and equipment inspection every other year or so until they're retired from road use... or until they change the testing requirements again...
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
J Wedge Modified TR-8 in California...I need help to pass smog...HELP!!!! Triumph 25
M Smog pump and alternator brackets Spridgets 0
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
Y Passing the smog test MG 17
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
C TR6 Need to pass CA smog, Los Angeles Triumph 4
B MGB Calif. smog questions MG 29
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
J MGB Smog test fail MG 11
Bob Claffie MGB MGB smog control ???? MG 12
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
P E Type V12 PCV & Smog systems Jaguar 8
1 Smog/Emissions question MG 8
SCguy Wedge My TR8 failed CA smog! Triumph 9
pakiwi Removing Head with Smog Equipment Spridgets 8
B New Proposed California Smog Legislation Triumph 5
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
neilh passed CA Smog - now it won't idle! Spridgets 3
ncbugeye Smog oil-filler cap Spridgets 3
SCguy Wedge My new TR8 and CA Smog [Latest picture] Triumph 26
S Smog? Mine's a '76? Story of My Life... Triumph 9
G smog equipment MG 29
drooartz Smog head 1275 question Spridgets 33
skinsgamer Passing Cali smog Spridgets 6
G Is there a procedure to remove the smog equipment? Spridgets 1
H Spitfire My Spitfire declared smog exempt! Triumph 0
S Smog Equipment Removal MG 7
77_MG_Midget Issues passing SMOG testing Spridgets 2
Nunyas Smog Pumps... the Op check... MG 2
TNMGB What smog stuff am I missing here? MG 13
MattP Smog pump question MG 3
Bret D-Day in Poway - Smog Test! MG 9
A Removal of the Smog Equipment MG 39
RobSelina Removing all smog equipment and my heater Spridgets 13
M Removing smog devices MG 5
MrBlueSky Wedge tr8 air/smog pump?????? Triumph 6
Bret Smog Test Round #2 - A Happy Day! MG 0
Bret Smog test: Round #1 MG 20
X how to beat the smog test Restoration & Tools 4
M Spitfire Kalifornia smog and the Spitfire Triumph 18
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
