MGB 79 MGB - restoring emissions controls
BobS76
Helping my son restore the emissions controls to his 79B so that he can get it registered in San Diego. The immediate problem appears to be the plumbing to the Gulp Valve. Apparently, there is a short piece of hose connecting one of the larger ports to a right angle fitting (Moss p/n 373-860) that installs in the manifold. Moss no longer sells this part but I found one on-line. Can someone confirm that the gupl valve is plumbed this way and let me know how the fitting installs in the manifold.
Thanks,
Bob
B
BobS76
Thanks, that DOES help, but my main question was about the right angle fitting into the manifold. When I gave him the car, it had the 2 piece manifold and he sourced a reconditioned manifold with out the fitting.
Deleted member 8987
For California, you will need the exact exhaust manifold. If I remember, BIG hole, 1" or maybe 7/8", and the boss for the hole wasn't there on pre-emissions vehicles, so you cannot just drill and tap a manifold.
Start asking and looking...and specify that 90 degree bit installed and intact. And NEVER try to remove one unless you are prepared to drill, grind and re-thread the manifold to get a new one in.
Yeah, you might luck out, but chances to well in favour of the house you will just snap it off.
And anti-seize everything.
Got the cat?
Jerry
I worked on a 78 and had to buy a new cat to get the smog to pass. The new cat glowed red and caused vapor lock. Good luck.
Deleted member 8987
and it is in violation of Federal Law to install a used cat. Period.
It really isn't worth the effort to try to get an old Brit vehicle to pass.
The law used to say, these are the minimums and maximums...unless it is British, and you have the importation paperwork from the Feds stating different numbers are allowable....and I never came across anyone with those papers.
We would fight those things for weeks with an analyzer hooked up and still couldn't get them to pass.
Get it out of state and sell it, buy one old enough it is not subject to emissions testing, and come back into the state.
Opinion.
tony barnhill MGB Restoring an MGB Works Hardtop MG 45
D MGB Hi, Restoring a 1964 MGB MG 18
G MGB interested in restoring our MGB MG 5
S MGB restoring 5th MGB MG 1
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
