Slippery reverse gear
4tecdog
Shall be getting frog out of her hibination soon maybe after storm Doris, had a small issue last year slipped out of reverse on a few occasions and had to really make sure I put a little pressure on the stick when finding reverse, Any ideas or inspection procedures I can do? Don't fancy a full strip down unless really nessesary. The unit is a 1275 stage2 with a CR box.
Jim_Gruber
Bet you have the same issue in 1st as well.
Gerard
The reverse fork introduced and intermediary gear between 1st and the layer, causing the mainsheet to tune in the opposite direction. The gear itself and move freely (no detent) The most likely issue is a weak spring or missing detent or a worn shift rod. Another possibility would be worn thrust washers on the layer allowing too much for and aft movement which would encourage the intermediary gear to disengage. There's not much to be done about either without removing the gearbox.
4tecdog
4tecdog
Thanks Gerard I suspect a weak Spring the gearbox has only done 2k
since a rebuild ten years ago so has been doing a lot of standing. Looks
like a removal at some stage.
Gerard
Perhaps the detent peg was omitted? I've taken a lot of gearboxes apart where these little parts were omitted or missing.
4tecdog
4tecdog
Any suggestions which workshop manual I should pick up if doing a gearbox repair on the frogeye. Have a Haynes
for the big Healey but not too impressed especially when it says the big Healey gearbox is removed from under the car??? Thanks to this forum for putting me right.
Gerard
Definitely the Bentley!
Deleted member 8987
That's hilarious, given the discussion on the forum about how wonderful Haynes manuals were.
Another thing I have seen is binding of the boot (or carpet if installed) on the gearshift lever when all the way over and in for reverse.
Trying to bring up a photo in my mind of how these are laid out, but you might want to just remove the boot and try it. I seem to recall (through the fog) that rear trans mount too low can cause some issues there as well...but, again, been a while since I was into a BE.
4tecdog
4tecdog
Thanks I will check that could well be the problem as I have not experienced any issues with first yet. Any particular Bentley publication for a mark 1 with discs and a 1275 power plant.
Gerard
I don't think there is a single one that covers from MKI thru MKIV, so you may need to get two, but this one would cover most of it, and certainly the upgrades you mention.
4tecdog
4tecdog
Didn't know there were so many manuals for Sprites, going to a major uk restoration show in April will have a rummage through some of the book stalls see if I can pick up any Bentley manuals. Including the one you suggest.
twas_brillig
Also have a look for the original blue covered Sprite factory manual. A memento as much as a reference. Doug
bigjones TR2/3/3A Difficult to engage Reverse Triumph 15
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
J Issue with Reverse Spridgets 2
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
NutmegCT Tire pump in reverse? Restoration & Tools 5
S MGB 78 MGB cannot shift into reverse MG 3
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
FlyingCat Spitfire Reverse Switch Triumph 2
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Popeye General Tech A-type OD question: Avoiding operation in reverse Triumph 7
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
G MGB Turn signal, reverse and brake lights MG 9
Sopwith_Camel reverse welly Gromit? Jaguar 7
T TR2/3/3A TR3A Reverse Light Triumph 15
N BJ8 Noise when going from reverse to forward Austin Healey 2
Lutz Kramer Reverse Gear Selection Austin Healey 2
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
B TR6 Reverse light wiring harness routing Triumph 4
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
Boggsy64 MGB Reverse and overdrive switch MG 13
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
nevets used reverse with OD switch on Austin Healey 12
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
A Where in the flip is REVERSE??? Triumph 2
T reverse switch on transmission Spridgets 9
1 T-Series How to remove reverse light switch on gearbox MG 3
M TR6 tr6 reverse lights switch Triumph 2
S TR6 TR6 Jamming in reverse ! Triumph 9
DGill Reverse gear some times does not work MG 3
R Wont Go Into Reverse MG 6
DrEntropy Reverse spotting! Spotted 4
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
G Reverse lamps MG 3
scott_74 Reverse Lamp Switch Spridgets 1
K Reverse bleeding Spridgets 8
hondo402000 TR6 TR6 reverse light switch wiring help Triumph 4
T No reverse Triumph 8
D Reverse Polarity? Spridgets 2
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
R BJ8 - Can't find reverse Austin Healey 1
B TR6 TR6 Jumping out of Reverse Triumph 5
glemon MGB MGB Reverse Hard to engage MG 4
