Reverse gear some times does not work
DGill
We are driving a 1970 MGB with a later style OD unit. When we stop some times it is like the OD disingages and there is no reverse. Is there a adjustment to the OD unit or does the OD need to be in direct drive for reverse to work?
Deleted member 8987
Should be electrically isolated in all but third and fourth. Off another forum:
"There is an isolator switch oc the gearshift linkage which only allows overdrive in 3rd & 4th. The switch arrangement also prevents o/d engagment in reverse gear.(sudden death for o/d unit). When down shifting into second the o/d is automatically disengaged and when upshifting back into 3rd will re engage unless the stalk switch is used."
You do NOT want to be in OD and reverse at the same time.
If you deselect the OD, does reverse work okay?
bob67bgt
Sometimes later O/Ds stick in O/D and do not just disengage when you are not in 3rd or 4th. I would try warming it up and then changing the oil. Quantum Mechanics recommends 30 non detergent motor oil as the factory did. If that does not work it might be worth a call to John at Quantum. Bob
R Bugeye reverse gear Spridgets 6
4tecdog Slippery reverse gear Spridgets 12
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
Lutz Kramer Reverse Gear Selection Austin Healey 2
356roadster BN1: Reverse gear plunger desperately needed Austin Healey 4
E can't find reverse gear Spridgets 18
bigjones TR2/3/3A Difficult to engage Reverse Triumph 15
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
J Issue with Reverse Spridgets 2
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
NutmegCT Tire pump in reverse? Restoration & Tools 5
S MGB 78 MGB cannot shift into reverse MG 3
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
FlyingCat Spitfire Reverse Switch Triumph 2
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Popeye General Tech A-type OD question: Avoiding operation in reverse Triumph 7
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
G MGB Turn signal, reverse and brake lights MG 9
Sopwith_Camel reverse welly Gromit? Jaguar 7
T TR2/3/3A TR3A Reverse Light Triumph 15
N BJ8 Noise when going from reverse to forward Austin Healey 2
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
B TR6 Reverse light wiring harness routing Triumph 4
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
Boggsy64 MGB Reverse and overdrive switch MG 13
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
nevets used reverse with OD switch on Austin Healey 12
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
A Where in the flip is REVERSE??? Triumph 2
T reverse switch on transmission Spridgets 9
1 T-Series How to remove reverse light switch on gearbox MG 3
M TR6 tr6 reverse lights switch Triumph 2
S TR6 TR6 Jamming in reverse ! Triumph 9
R Wont Go Into Reverse MG 6
DrEntropy Reverse spotting! Spotted 4
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
G Reverse lamps MG 3
scott_74 Reverse Lamp Switch Spridgets 1
K Reverse bleeding Spridgets 8
hondo402000 TR6 TR6 reverse light switch wiring help Triumph 4
T No reverse Triumph 8
D Reverse Polarity? Spridgets 2
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
R BJ8 - Can't find reverse Austin Healey 1
