Trevor Triumph
There is fluid in the clutch master cylinder. When moving the transmission up-shifts smoothly through the gears. Driving to the show site this morning I stopped at a light and when I put the shifter from neutral to second, then to first, there was a grinding noise. At the show I was able to back up but, grinding again. Driving home the transmission shifted through gears well enough. At home I couldn't shift into reverse, after pumping the clutch pedal or turning the engine off. I'm wondering about the hydraulic system- the washers are close to ten years old. Or is there more serious trouble in the transmission?
T.T.
T.T.
