Reverse bleeding
drooartz
I've certainly bled quite a bit on my Bugeye (and on the floor, my jeans, lots of Band-Aids...). :devilgrin:
(Sorry for the snarky reply, just couldn't resist.)
I've got speed bleeders on my Bugeye, and those have seemed to work very well. I'm assuming by "reverse bleed" you mean some sort of suction on the M/C and pulling fluid from the bleeders?
nomad
Considering there is high points in the tubing above the master cylinder that I have always blamed for making for difficult bleeding I would expect reverse bleeding to work quite well. I have been frustrated almost enough to spring for equipment to do just that. Being a cheap skate won out though!!
KA.
twas_brillig
The thread got me intrigued; did an Internet search and found a suggested DIY system for motorcycles: https://www.moccsplace.com/images/brakes/bleeder/bleeder.htm
I've gone to speed bleeders on one of our non-running BEs; I'm presuming that I wouldn't be able to reverse bleed these, but would appreciate some wisdom from the group.
Doug
JPSmit
I am certain that a while back (I'm thinking 18 mos - 2 years) we had a thread on a couple folk who had plumbed in a nipple that sat higher than the rest if the system.
i miss the Great Pumpkin.....
m
jlaird
Yea I too miss Tony and the phone calls every few days, dam.
Platinum
ugh.
bigjones TR2/3/3A Difficult to engage Reverse Triumph 15
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
J Issue with Reverse Spridgets 2
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
NutmegCT Tire pump in reverse? Restoration & Tools 5
S MGB 78 MGB cannot shift into reverse MG 3
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
FlyingCat Spitfire Reverse Switch Triumph 2
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
4tecdog Slippery reverse gear Spridgets 12
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Popeye General Tech A-type OD question: Avoiding operation in reverse Triumph 7
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
G MGB Turn signal, reverse and brake lights MG 9
Sopwith_Camel reverse welly Gromit? Jaguar 7
T TR2/3/3A TR3A Reverse Light Triumph 15
N BJ8 Noise when going from reverse to forward Austin Healey 2
Lutz Kramer Reverse Gear Selection Austin Healey 2
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
B TR6 Reverse light wiring harness routing Triumph 4
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
Boggsy64 MGB Reverse and overdrive switch MG 13
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
nevets used reverse with OD switch on Austin Healey 12
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
A Where in the flip is REVERSE??? Triumph 2
T reverse switch on transmission Spridgets 9
1 T-Series How to remove reverse light switch on gearbox MG 3
M TR6 tr6 reverse lights switch Triumph 2
S TR6 TR6 Jamming in reverse ! Triumph 9
DGill Reverse gear some times does not work MG 3
R Wont Go Into Reverse MG 6
DrEntropy Reverse spotting! Spotted 4
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
G Reverse lamps MG 3
scott_74 Reverse Lamp Switch Spridgets 1
hondo402000 TR6 TR6 reverse light switch wiring help Triumph 4
T No reverse Triumph 8
D Reverse Polarity? Spridgets 2
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
R BJ8 - Can't find reverse Austin Healey 1
B TR6 TR6 Jumping out of Reverse Triumph 5
glemon MGB MGB Reverse Hard to engage MG 4
