A quick 1500 fix for when you go for reverse and rip off your shift lever!
bthompson
I was noodling around today, and thought I'd share the fun with all of y'all!
You take off your shift boot, and are greeted by this:
A quick inspection reveals that the nylon gromit has shattered. It holds the shift lever in place against spring pressure under the retaining cup. When it breaks through the top of the cup, there's nothing holding the shifter in place. There's no way to remove the gromit, replacements are unobtanium, and you don't want to pay big bucks for a whole new lever assembly that'll probably break again anyway.
Here's one solution: cut the top off of a tennis ball, drill a 1/2" hole, cut a slit in it, and slip it over the broken gromit.
Assemble it with the retaining cup over the tennis ball, and drive on. It feels exactly like what you'd expect shifting through a felt-covered thick rubber washer would feel like.
Here's the problem: it lasts about a year until the ragged edge of the gromit wears through the rubber and works itself through. Then --oops-- you go for reverse, rip out your shift lever, and you have to cut up another tennis ball. I've been doing this for years, and keep an extra fresh tennis ball slice in the trunk for when the old one lets go.
I've gotten tired of the routine, and thought I'd try something new -- a large cotter pin...
...bent into shape...
...and clipped on the shifter over the remnants of the nylon gromit. (I considered using a clevis pin, but they are very hard to bend.)
The retaining cup holds the cotter pin, gromit, and spring in place. Shifts feel a little looser, and reverse doesn't take as much effort to get into. The spring isn't as tight, and the rod pivots through the cotter pin, instead of sliding and wearing the tennis ball.
Voila! Button up and drive away. Time will tell if the cotter pin is a better solution than the tennis balls were, or if the pin will loosen up over time.
Jim_Gruber
Another wonderful innovation sponsored by the "We Tight Club." Frank C would be proud of this one.
JPSmit
Love McGyver solutions!
nomad
Just want to say that most bearing house's stock nylon bar stock and with a mc gyvered fixture to hold it in a drill press and a course rasp you could probably make a exact replacement.
End the worry of a failure in traffic.
Kurt.
JPSmit
Strikes me that this is a problem screaming for a 3D printer solution
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T MGB Quick question about something that don't really matter just want to know. MG 9
dougie A Quick Trip Around Oulton Park.... Austin Healey 3
S Wedge tr7/8 quick release steering wheel Triumph 0
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
P TR6 Quick starting Triumph 2
S MGB 1980 MGB quick question MG 2
2billydavies TR2/3/3A Just a quick thanks to everyone who helped with my questions Triumph 7
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
judow Can't post except in quick reply and other issues FORUM Navigation Questions 0
Willie_P TR4/4A Quick HELP - TR4 fender beading.... Triumph 3
H quick insulation paint color quesrion Austin Healey 7
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
S TR6 Quick TR6 alternator question Triumph 6
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
M Quick tachometer wiring question on a '65 Spridgets 10
Jim_Gruber Quick Engine Install for Bugsy II Spridgets 22
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P Help: quick hub torque questions Triumph 3
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
aeronca65t MGB Quick MGB motor swap MG 3
MCNX_BFF Quick catch-up and trailer question Triumph 8
RJS Radiator Fan Bolts - need quick help Triumph 4
skelly Quick question from a newbie Spridgets 10
B Smelling like fuel and oil after a quick drive? Austin Healey 29
PatGalvin Captive nuts?? quick question Triumph 7
abarth69 quick help needed Spridgets 3
JPSmit Quick Spark plug question Spridgets 10
Coyote1 Need a quick measurement Triumph 7
T TR4/4A Two quick OD TR4a wiring questions Triumph 7
regularman Quick, right now go to ESPN Spridgets 2
glemon Quick Easy Removeable Cupholder Triumph 4
Randy Forbes Quick's trip to the Morgan Motor Co., LTD... Austin Healey 4
J Details, Details. Quick questions. Spridgets 11
PATR8 a quick look at the Pittsburgh Craigslist Triumph 1
drooartz MGB That was quick: MGB heading to my garage MG 24
Sarastro Quick dumb transmission question Spridgets 9
S A quick introduction Spridgets 21
T Quick fuel pump question - mounting angle MG 3
S Quick Release Steering wheel hub Triumph 1
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
M Spitfire Quick fix for spitfire sag Triumph 7
bigjones HS4 - quick question MG 6
QuickSilver A Quick Return To The Fold MG 11
