Spitfire Reverse Switch
FlyingCat
I finally got my 1980 Spitfire (1500 Federal) running (thanks, everybody!), and now I'm working through the very long list of things that still don't work... like the reverse lights. I have the rear running lights working, so I don't think the trouble is in the back. I think it might be the switch... but I haven't a clue where that is on my car. I'm assuming it's something mechanical (I mean, what else could it be?) that is engaged when I put the car in reverse, so it has to be somewhere around the transmission. But like I say, I don't know where they've located that switch. Wiring diagrams are no good in actually locating where something is. Anybody have any clues?
trrdster2000
It's at the back of the transmission shaped like a eyedropper with two wires coming out of it. Green and green/brown I think.
Run on and off from the cam on a shaft in the transmission. Push on.
FlyingCat
FlyingCat
Thanks! Got it. There are no wires coming out of the one on my car, so it really looks like... nothing. Just another bolt.
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
Boggsy64 MGB Reverse and overdrive switch MG 13
nevets used reverse with OD switch on Austin Healey 12
T reverse switch on transmission Spridgets 9
1 T-Series How to remove reverse light switch on gearbox MG 3
M TR6 tr6 reverse lights switch Triumph 2
scott_74 Reverse Lamp Switch Spridgets 1
hondo402000 TR6 TR6 reverse light switch wiring help Triumph 4
T Reverse light switch Triumph 8
jjbunn Missing Reverse Light Switch Triumph 6
jhorton3 Reverse Light Switch Ideas Spridgets 6
M GT6 GT6 reverse light switch Triumph 4
bash Reverse Switch Test Triumph 2
jerrybny Reverse Lights Switch Triumph 10
S Reverse Warning Switch - Newie Spridgets 2
S T-Series MG Midget 1275 Reverse Light Switch - Help Needed MG 1
bigjones TR2/3/3A Difficult to engage Reverse Triumph 15
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
J Issue with Reverse Spridgets 2
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
NutmegCT Tire pump in reverse? Restoration & Tools 5
S MGB 78 MGB cannot shift into reverse MG 3
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
4tecdog Slippery reverse gear Spridgets 12
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Popeye General Tech A-type OD question: Avoiding operation in reverse Triumph 7
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
G MGB Turn signal, reverse and brake lights MG 9
Sopwith_Camel reverse welly Gromit? Jaguar 7
T TR2/3/3A TR3A Reverse Light Triumph 15
N BJ8 Noise when going from reverse to forward Austin Healey 2
Lutz Kramer Reverse Gear Selection Austin Healey 2
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
B TR6 Reverse light wiring harness routing Triumph 4
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
A Where in the flip is REVERSE??? Triumph 2
S TR6 TR6 Jamming in reverse ! Triumph 9
DGill Reverse gear some times does not work MG 3
R Wont Go Into Reverse MG 6
DrEntropy Reverse spotting! Spotted 4
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
