Any ideas on why the (A-OD) transmission would jump out of reverse?
Happens when it has a load (backing up a hill) or when warm.
After it jumps out of reverse the shift mechanism locks into that gear. If you push the clutch in and stop the engine it will easily go back into neutral.
This started in baby steps after the restoration then gradually got worse. It does not jump out of any gear at any speed in forward or in OD. The Ttansmission was rebuilt years ago and set.
Thanks.
AK in STL
Thanks.
AK in STL
