simple question on fenders
John Moore
Yes, in 74.5 was the switch to rubber bumper fenders. The cutout for the front blinker is different. Later fenders could be used, but you would have to weld up the blinker hole to make it work.
John Moore
Guy,
I just looked at your photos. I hate to be the bearer of bad news, but there is a good chance your sills are rusting inside out. I noticed in the photo of your rt fender the end of the castle rail has rusted away. That happened to my B too, it's bad news. I would have it checked out. The sills are the major load bearing support structure of the MGB and unfortunately are prone to the tin worm. Once it gets inside, it eats the B inside out. My outer sills were replaced sometime in the past, and the inner sills were poorly patched. On my car, now that patch has started to rust out. Not good. I'm the in the midst of a full sill replacement. Not fun.
Moose33
Moose33
yeah, it's in dire need of some major help.
the worst part is even though the passenger side door is sagging, the drivers' side has some rather significant damage where the sill buckled and so did the jacking point.
I've got a friend who is getting ready to do both sides of his 73b. He's rather handy with a welder and we are going to use his car as a guinea pig (so to speak), and if that goes well then we will do mine in the fall (and put new floors in as well).
I don't intend on driving mine much more than up and down the driveway a couple times a month until we start the structural repairs.
It's a project and I knew that when I bought it.
I'm trying to do it all myself and save some $$$ (I'm not all amatuer, I do have some formal mechanics training) my MG guru said it would cost approx $1600 Per Side to have his guys do it.
On a good note though, I know the Engine runs and the clutch is good /ubbthreads/images/graemlins/grin.gif
John Moore
Yeah, it's very expensive to have it done. Same as you and your buddy, I'm doing it myself. I bought a mig a few weeks ago and I'm teaching myself to weld. I'm starting with little projects and slowly moving to getting the sills done. That's great your going to learn on your buddies car! lol So far I've found it's not the welding in new panels that's difficult. Its cutting out the old rusty ones. It's timing consuming, hard work.
But glad to hear about he engine and clutch!
bighealeysource simple choke question on BN2 Austin Healey 2
R Simple question about metal Spridgets 18
M Simple Rebuild question....... Spridgets 7
jbowlby Simple question for a simple mind Spridgets 8
bcbennett Simple alternator question Triumph 4
Newkie Simple Brake purchase ?question? MG 10
jjbunn Heater Wires: a simple question! Triumph 3
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
bcbennett Simple clutch question Triumph 15
1 Simple question: what is this under the hood? MG 13
Y Choke Cable [very simple question] MG 5
John Turney No Job is Really Simple Austin Healey 17
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
Bayless The very simple rotisserie Spridgets 3
glemon General TR Simple Improvement Valve Cover Washers Triumph 2
H TR4/4A A simple solution for separating axle and hub. Triumph 32
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
trotti Simple tool for steering box adjustment Austin Healey 5
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
WillR MGB What happened to a simple engine refresh? MG 12
mgedit Software for Simple Electrical Diagrams Triumph 9
Moseso A simple oil change gone South Triumph 16
E plain and simple Restoration & Tools 4
L Simple fix for leaky tappet cover Austin Healey 0
T simple addition for electrical safety Spridgets 7
T OMG! How can it be this simple????? Thanks Guys! MG 6
T I'm sure this is simple but... MG 7
T Lesson: Check the simple stuff first.... MG 1
Jim_Gruber Never overlook the simple stuff Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
M MGB 1973 MGB....a few simple questions MG 5
2wrench Simple yet important engine timing questions Triumph 11
roscoe Simple audio system Austin Healey 8
M "Installation is simple..." Spridgets 8
AUSMHLY How "NOT" to make a simple cup holder -BJ8 Austin Healey 17
healeyboz As simple as it sounds..... Spridgets 8
John_Mc Aaah...the simple things! Triumph 6
V Car is running out of breath/ other simple probs. Triumph 4
EMGEBE TUNING, HOW SIMPLE IS IT REALLY? MG 8
P Newbie Intro and Some Simple Questions MG 6
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
