TUNING, HOW SIMPLE IS IT REALLY?
EMGEBE
Hi guys!
IM getting rather tired of taking my car to my mechanic and getting ripped of for what ive been told is a BLODDY SIMPLE TUNE!
I'm running twin SU's (im pretty sure 1&3/4)
Don't my air filters look pERTy /ubbthreads/images/graemlins/smirk.gif
Is there any good internet tutorials on setting up a nice tune/performance tuning/advancing etc...
Cheers
Jarrod
MattP
Re: emgebe
The post on the manuals has a good SU manual that I have already printed out, it looks helpful, especially in the way it breaks down the whys and what fors.
dklawson
Re: emgebe
Setting up the ignition system is straight-forward and explained well in most manuals. Though I can tune SUs, I never have felt I was doing it right. I have the Haynes SU manual and the appropriate sections from the factory manuals for my cars. Still... I'd like a seasoned pro to walk me through (hands on) proper mixture setting on SU and Stromberg carbs. That said, you can get the mixture close enough by following the basic steps in the manuals.
em754
Re: emgebe
If your in the MGCC, see if they have the SU rebuild and tune-up video, easy to follow, i found it a great help!
EMGEBE
EMGEBE
Re: emgebe
em754 - yeh i am in the Vic MGCC, do they rent it out or something? :p
How long does it go for?
I'd love to get my hands on a copy
Will ask next time /ubbthreads/images/graemlins/thumbsup.gif
trrdster2000
Re: emgebe
EMGEBE, setting the carbs to the correct mixture can be tricky, but get them as close as you can, then drive the car a few miles, get out and pull the front plug and rear plug aand if it's not gray/brown, you will need to turn a flat or two on the jet. If they are black, too rich, screw the adjuster up and very white, too lean, adjust down. If the front one seems ok then only adjust the back one or vise versea. Now you drive it a few more miles and look again, after a few tries you will get the feel of rich and lean. Now you have the mixture right, get the idle right and have the control linkage adjusted so when you pull on the accelerator cable the little flap on each carb moves at the same time, (takes a few tries). Wayne
em754
Re: emgebe
I think it is between 1.5 to 2 hours long, very handy though!
Here in Sydney it was $4 for the month between meetings. Just check the club library.
Banjo
Re: emgebe
Frequent tunings are often caused by a mechanic trying to make up for a weak or faulty ignition system by adjusting the carbs. It can also be caused by worn parts like throttle shafts or distributors that will quickly cause the state of "tune" to deteriorate.
See if you can find a seasoned LBC mechanic who can give you an in depth analasis of the mechanical parts and not just the "simple tune" adjustments for a reasonable price. If you find something hidden it may greatly extend the intervals between tune ups.
Doing a simple tune yourself isen't difficult, but learning it is a lot easier in person than by a book.
Send me a plane ticket. I'll gladly come to Melbourn and set ya right up /ubbthreads/images/graemlins/jester.gif
Repro
Re: emgebe
They should be 1 1/2" SU's.
And if the floats are adjusted correctly, you only have two adjustments to make, the mixture and the idle.
I find the old rubber hose the easiest to get them balanced.
Like they say, it's not rocket science.
All the best, Ross.
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 tuning webbers Triumph 3
jehuie Tuning up a 1275 Spridgets 17
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
D 62 tri-carb tuning question Austin Healey 8
M Carb Tuning Austin Healey 40
M Carb tuning [again] Austin Healey 2
CJD TR2/3/3A SU Carb Tuning Triumph 17
E TR6 Crankcase venting and general tuning advice? Triumph 29
AN6-TX Tuning/Tweaking for Altitude Spridgets 11
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
Martinld123 Tuning H6 100 M carbs Austin Healey 10
R General Tech TR3/4 Tuning Triumph 27
HealeyRick Sprite Tuning Information Memos Spridgets 0
HealeyRick Big Healey Tuning Information Memos Austin Healey 0
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
KVH General Tech Timing and Valve Tuning--with a plastic fan Triumph 4
M wire wheel spokes "tuning" Austin Healey 8
S Procedure for setting and tuning HD8s? Austin Healey 10
C BMC Special Tuning Data Austin Healey 9
KVH TR4/4A Tuning the TR4A Triumph 16
S Tuning the Sprite Spridgets 3
L 100 BN1 Tuning instructions ebay Austin Healey 3
7 General Tech Engine vacuum, tuning question Triumph 7
7 General Tech Tuning an engine with a vacuum gauge Triumph 5
Coyote1 TR6 TR6-tuning new motor with mods Triumph 6
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
T SU HS6 tuning - lifting pin question Triumph 11
M TR4/4A 67 TR4A, any tuning mods with Redline/MMO in gas? Triumph 3
HealeyRick "Tuning BMC Sports Cars" Spridgets 11
Westfield_XI Weber tuning breakthrough Spridgets 14
M Carburetor tuning - setting mixture Triumph 6
Nunyas Saw this at a "tuning shop" Other Cars 0
hondo402000 Tuning my Webers now Triumph 13
af3683 Tuning SU H6 Carbs Triumph 5
drooartz MGB MGB tuning conundrum MG 25
T tuning carb timing Austin Healey 17
Stewart Tuning experts MG 4
PAUL161 Tuning the 1800 engine. MG 5
W Carburetor tuning Triumph 18
M Help with Tuning Stromberg 175CD Carbs in Houston Triumph 37
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
drooartz Tuning help Spridgets 16
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
M su carburetor tuning Triumph 7
drooartz Progress: a little tuning Spridgets 0
D Wideband O2 Sensor for Tuning MG 1
