Opinion wanted regarding the Heralds engine.
The engine is quite warm at this point. Plugs are nice and clean.
Here is a video showing the vacuum gauge hooked up to manifold vac at idle.
Vacuum is reasonably high, with the needed vibrating a bit.
The engine is still fairly noisy, at speed it is very noisy. I have gone over the exhaust and didn't find any leaks.
Adjusting the vacuum has almost no effect on vacuum level until timing is so far out that the engine starts stumbling.
