Carburetor tuning - setting mixture
M
Member 10617
A few days after I purchased my TR3 in 2009, my mechanic gave me some helpful pointers on how to set the mixture. One thing he said, which went in one ear and out the other because of my inexperience, was "Always remember that the carb you are lifting is not the carb you are checking. If you lift the front, you adjust the rear."
In the ensuing couple of years, I have read and been told by many people that when you adjust the mixture, you lift the pin on a carb and you turn the adjusting nut ON THAT CARB.
But recently, I was reading a manual for a 1954 XK 120, with H6 SU carbs, and found following:
"Next check the mixture strength by starting the engine and raising the lifting pin of the FRONT CURBURETTER. ... If...
... (a) The engine speed increases and the engine continues to run at increased speed, this indicates that the mixture strength of the REAR CARBURETTER is too rich....
... (b) The engine speed increases and the engine then stops, this indicates that the mixture strength of the REAR CARBURETTER is too weak.
... (c) The engine speed increases momentarily and then decreases but the engine continues to run somewhat bumpily, then the mixture strength of the REAR CARBURETTER is correct.
Repeat the operation, lifting the REAR CARBURETTER piston and testing the mixture setting of the FRONT CARBURETTER."
In other words, When you lift the pin or piston on one carb, it is THE OTHER CARB THAT NEEDS ADJUSTING.
Any thoughts on this procedure?
trrdster2000
Ed, I find that very interesting, as over the years, using the other system has made me adjust the other carb to get things to even out. The only true test is the five mile plug test,, then you get the internal picture of each cylinder.
Wayne
M
Member 10617
Wayne,
You are right about the really true test. My mechanic, after telling me about the procedure, added: "The proof of proper running mixture is a 'cut test.' This is done by running the car at full throttle in third gear, and then letting off and pushing the clutch down. Then shut off and coast to a stop. Remove spark plugs and look at their color." I have done this to check on some problem I thought I was having with #1 plug.
TR3driver
Great Pumpkin - R.I.P
It may vary with the intake manifold configuration; but on a TR3 I find that the result from lifting the pin indicates primarily the carb you are lifting the pin on. There is some impact from the other carb's mixture though; so you do have to work back and forth until both are 'right'.
M
Member 10617
Randall,
Yes, indeed... back and forth seems to be the way.
I also start with a colortune check to set a kind of "baseline," and then turn to the lift-to-pin/lift-the-piston routine.
EV2239
The Brit manufacturers all set their main jets on SUs 35-38 thou below the jet bridge and provided the float heights are correct and the needles sealing, the car will run perfectly.
My Bentley, my Healey and My TR are set this way and they run exactly as they should.
Make sure the butterflies are also carefully synchronised.
Ash
hondo402000
I use an O2 meter but then I have to I have the cursed Webers infinately adjustable!@@##%$%#$%
you know who
Hondo
W Carburetor tuning Triumph 18
M su carburetor tuning Triumph 7
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
