Wideband O2 Sensor for Tuning
DJThom
Has anyone used a wineband oxygen sensor for tuning? Specifically I'm thinking of Innovate Motorsports LM-1 or LM-2.
I can't think of a better way to find out how rich/lean you are running over a wide range of RPM and load conditions, but if there is one I'd like to know about it.
Yeah we use them on the dyno with engines, but it's somewhat of an illusion to be able to tune engine for all rpm ranges with our carbs. What a AFR gauge will do for you is allow you to tune at a number at WOT then let the rest take care of itself.
B Wideband Sensor Install Racing 3
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
A MGB Stuck water temperature sensor MG 26
R Thermal sensor Spridgets 2
G Thermo Fan Sensor Austin Healey 5
Basil DIL's O2 sensor problem - SOLVED Other Cars 11
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
N BT7 water temperature sensor removal Austin Healey 13
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
S BJ7 frozen temperature sensor to block Austin Healey 17
JFS TR2/3/3A Temp Sensor Removal Triumph 6
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
steveg Has anyone used a knock sensor? Austin Healey 0
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
sim 02 sensor question Spridgets 13
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
C How to remove temp sensor at block? Austin Healey 16
Rut Temp sensor Spridgets 9
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBRandy What Connector for this sensor? [TKC5050] Triumph 20
jhorton3 Brake Pressure Sensor Options Spridgets 3
R wide band O2 sensor recommendations? Spridgets 10
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
martx-5 SU carbs and the Oxygen Sensor Triumph 2
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
L Temperature sensor relocation in BE with A 1275 Spridgets 8
M Help... ! Coolant temperature sensor leaking.. Austin Healey 4
D Mass Air Flow Sensor 1997 XJ6L Jaguar 5
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
JodyFKerr Spitfire Brake pressure sensor leaking ['78 Spitfire] Triumph 6
C TR2/3/3A TR3 temp sensor hole plug? Triumph 4
Tinkerman TR2/3/3A TR3A Temp Gauge Sensor Tube Routing Triumph 2
I 60 Bugeye temp sensor wire path help please. Spridgets 0
L Water temp sensor placement [secondary] Spridgets 7
jlaird O2 sensor Other Cars 9
W Plugging the temperature sensor hole Spridgets 3
L O2 sensor placement Spridgets 5
bluemiata90 Wedge TR8 COOLANT LEVEL SENSOR LOCATION Triumph 4
M Sensor Question on 87 XJ6 Jaguar 5
Trick6 Air Fuel Ratio Sensor/Monitor Triumph 18
PAUL161 Not British Car Related, Oxygen Sensor? Restoration & Tools 40
71tr Temp Sensor for Electric Fan Triumph 18
Brosky Placement of temp sensor for cooling fan Triumph 33
Jim_Gruber Coolant Leak / Temp Sensor in the block Spridgets 10
N Adding an O2 sensor to exhaust? Triumph 25
6 sensor?????? Jaguar 3
ronzet Water Temp Sensor Fitting on Radiator Austin Healey 10
K TR2/3/3A TR3untapped power from SU needles re Oxygen Sensor Triumph 24
