I'm sure this is simple but...
tdskip
How do you remove the bearings to completely disassemble the hub from the backing plate?
Steve_S
The hub pulls off. It's set onto a spline, which could be corroded and stuck. I have a factory hub puller in case it comes to that, but a universal puller should work. Make sure you have the nut AND tapered washer out before attempting removal.
bob67bgt
looks to me like a mga 1500 front hub. If you do not have a puller then bolt the wheel on and give it a kick from the backside. Bob
bob67bgt
The bearings are just a interference fit on MGA.s. They can be a real PITA to get off the front stub axle. Sometimes 2 crow bars will also work if the puller is not available. Bob
Deleted member 3577
AutoZone will rent you a 8" puller for free if you have access to one of their stores.
You can also rent a slide hammer.
Steve_S
Doh! I thought it was a rear hub. Guess I didn't notice the second hole in the back plate. :blush: I still have a puller if you need it. You can probably get a 3-jaw to work, just be careful of it slipping and dinging the first thread on the spindle.
Deleted member 3577
Yep...
Put a little, greased nut under the pointy end or a couple of pennies.
roscoe Not sure what I think of this Austin Healey 7
S Not sure on the ignition Spridgets 12
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
JPSmit Spotted - well I'm really not sure what? Other Cars 8
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
L I'm sure this is how Donald would have developed the Bugeye... Spridgets 16
D Cheap sure-shot alternative Spridgets 0
bigbadbluetr6 Not sure what this is. Do you? Other British Cars 7
7 Post-War Other All apart, really frustrated and not sure what to do. Triumph 15
DNK Not to sure about this!! Triumph 9
J Not sure how exhaust should fit? Spridgets 2
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
SilentUnicorn I am not sure what happened... British Motorbikes 5
DNK Pretty Sure... Triumph 9
Stewart I sure hope its just a head gasket MG 8
Randy Forbes It might be a slug, but it sure is pretty... Austin Healey 28
S Not sure what a switch is for on my car Triumph 8
judow Not sure if MG 1
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
Moseso TR250 [This time, I am sure what it was] Spotted 0
regularman Pretty sure my overheating problems are gone. Spridgets 9
C Driving lots; be sure to... Triumph 15
T Check this out! Make sure to look at all the pics Triumph 19
Bruce_B Just want to make sure before starting engine.... Spridgets 2
JPSmit Not sure it's worth it Spridgets 6
S HELP NOT SURE WHAT i HAVE Other British Cars 12
PATR8 Pretty sure this is a Healy Austin Healey 6
JPSmit I'm pretty sure but just in case Other Cars 5
Nunyas I'm not sure what to think.... MG 5
T Roll over video - not sure if it is an LBC Triumph 3
Mickey Richaud Well, It Sure Is RED! Triumph 6
AUSMHLY I'm thankful, I'm sure I'm not alone Austin Healey 2
jlaird Not sure Spridgets 12
JPSmit I'm sure we've discussed this before but... rims Spridgets 6
jlaird Would you beleive, sure you would. Spridgets 11
Bruce Bowker Not real sure about this paint. Lotus 4
B Unleaded but not sure Spridgets 4
B Overheating??? Not sure please help. Triumph 7
KLUTZ Not sure, but isn't this a ?? Triumph 4
Hegg No spark -- not sure why Triumph 14
J Smoking is that Bad? Yeh Sure, Help.. Other British Cars 12
W Pretty sure their blown Triumph 8
B Silly engine questions that i'm sure could be found in a FAQ somewhere.... MG 15
John Turney No Job is Really Simple Austin Healey 17
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
Bayless The very simple rotisserie Spridgets 3
glemon General TR Simple Improvement Valve Cover Washers Triumph 2
H TR4/4A A simple solution for separating axle and hub. Triumph 32
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
