General TR Simple Improvement Valve Cover Washers
glemon
Being kind of a fix it nerd I have spent way too much time in the nuts/bolts/misc. fittings aisle of the hardware store. Noticed some washers that are steel with bonded on rubber on one side. Bought three and used them on the rocker cover studs. For less than a buck the valve train noise from the motor is noticeably reduced. Washer for a TR250/6 are 5/16" i.d.
TR3driver
Great Pumpkin - R.I.P
Also available from McMaster-Carr. I used to use them for sealing rather than noise. They have a couple of styles, you want the ones that seal the threads as well as the surface. (Now I use a pair of custom nuts from Alexander Racing, that have O-rings in the bottom of them and a Triumph logo on top.)
glemon
glemon
Yes, the style I used looks as tough it is designed to seal as well, with a little extra rubber inside the perimeter of the hole, a snug fit.
John Turney No Job is Really Simple Austin Healey 17
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
Bayless The very simple rotisserie Spridgets 3
H TR4/4A A simple solution for separating axle and hub. Triumph 32
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
trotti Simple tool for steering box adjustment Austin Healey 5
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
WillR MGB What happened to a simple engine refresh? MG 12
bighealeysource simple choke question on BN2 Austin Healey 2
R Simple question about metal Spridgets 18
mgedit Software for Simple Electrical Diagrams Triumph 9
Moseso A simple oil change gone South Triumph 16
E plain and simple Restoration & Tools 4
L Simple fix for leaky tappet cover Austin Healey 0
T simple addition for electrical safety Spridgets 7
M Simple Rebuild question....... Spridgets 7
T OMG! How can it be this simple????? Thanks Guys! MG 6
jbowlby Simple question for a simple mind Spridgets 8
bcbennett Simple alternator question Triumph 4
T I'm sure this is simple but... MG 7
T Lesson: Check the simple stuff first.... MG 1
Jim_Gruber Never overlook the simple stuff Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
M MGB 1973 MGB....a few simple questions MG 5
Newkie Simple Brake purchase ?question? MG 10
2wrench Simple yet important engine timing questions Triumph 11
jjbunn Heater Wires: a simple question! Triumph 3
roscoe Simple audio system Austin Healey 8
M "Installation is simple..." Spridgets 8
AUSMHLY How "NOT" to make a simple cup holder -BJ8 Austin Healey 17
healeyboz As simple as it sounds..... Spridgets 8
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
bcbennett Simple clutch question Triumph 15
1 Simple question: what is this under the hood? MG 13
John_Mc Aaah...the simple things! Triumph 6
V Car is running out of breath/ other simple probs. Triumph 4
EMGEBE TUNING, HOW SIMPLE IS IT REALLY? MG 8
P Newbie Intro and Some Simple Questions MG 6
Moose33 simple question on fenders MG 6
Y Choke Cable [very simple question] MG 5
KVH General Tech Improvement to TR4A Muffler Triumph 1
ckeithjordan TR2/3/3A Gearbox Oil Improvement Triumph 7
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
maxwedge5281 front suspension or braking improvement Austin Healey 25
kyreb1862 Brake Light Improvement MG 3
19_again GT6 gt6+ power improvement basics Triumph 16
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
C Suspension improvement, or not? Triumph 19
