Ribbed case tranny in 948 bugeye
Gerard
Tomchillvet
newbe here---i don't know why i can't get it straight in my head about gerards post - putting a ribcase on a 948- can someone explain what needs to be done to get the ribcase to work on the 948- can i use the 948 clutch,fork,throwout bearing,flywheel or some combination of both that will work with the 1275 backing plate- sorry but don't want to get wrong parts--thanks
EVSpriteGuy Oil for 1275 ribbed case tranny??? Spridgets 1
B Smooth vs ribbed case ? Spridgets 9
W Original ribbed rubber door liners Spridgets 4
I What kind of glue to use for ribbed bugeye panels? Spridgets 7
I Source for ribbed material for inside bugeye door? Spridgets 5
W SEM Color Coat and ribbed door panels Spridgets 13
M 58 Sprite ribbed transmission issue [again] Spridgets 10
W Ribbed BE door liner Spridgets 5
W ribbed or smooth letters... Triumph 7
R RIB CASE SHIFT LEVER Spridgets 0
R Rib Case rebuild... Spridgets 5
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
John Turney Getting Speedometer out of the Case Austin Healey 6
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
A Wanted Rib Case Transmission Spridgets Classified 1
A Rib case problem Spridgets 7
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
F Wanted Smooth case trnny Spridgets Classified 6
6 Spridget Radio/Speaker Case Spridgets 4
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
C TR2/3/3A Transmission case ID Triumph 3
B Tar case glass mat batteries Austin Healey 8
mailbox General MG In case anyone needs a project or parts MG 0
Rhodyspit75 General TR Just in case you're not on my Christmas card list. Triumph 3
M Smooth case front cover Spridgets 9
T Basket case BJ8 values Austin Healey 10
B Purchasing Rib Case Spridgets 17
NutmegCT In case you need one - Other Cars 1
Gerard Source for front cover w/seal for rib case Spridgets 15
M Smooth case gearbox in early MKII Sprite? Spridgets 23
apbos Awakening the Smooth Case Transmission Spridgets 7
I Smooth case transmission help please Spridgets 11
M crank case vent pipe Austin Healey 11
rkep01 Question about front cover on smooth case trans Spridgets 5
L How to repair cast aluminum transmission case Spridgets 26
jlaird Rib Case arrived Spridgets 13
britndablood FS 1098 with rib case in North Carolina Spridgets 0
K TR2/3/3A TR3A...Tighten Diff Case Bolts? Triumph 5
tahoe healey Ken's case Austin Healey 1
HerronScott Alternator in generator case project? Triumph 2
TexasSprite Tach Case Interior Colors MG 3
TexasSprite Tach Case Interior Colors Spridgets 12
M Seeking 3.9 or 3.7 diff case or just gears Spridgets 3
B TR2/3/3A 57 TR3 Newbie...No spark? Basket case Triumph 31
bgbassplyr In case you missed British Motor Corp 1
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
