ribbed or smooth letters...
wifegonnakillme
Quick question, I need to order the letters for the bonnet (there are none there now) and i need to know which to order, ribbed or smooth. The car # is TS62932 - I remember reading somewhere that the holes for the "T" I think are offset in one set - on my car they are verticle, in fact there are no offset holes for any of the letters...
Any help would as always be appreciated...
Cheers,
Kerry
/ubbthreads/images/graemlins/canpatriot.GIF
Dan_Pasta
Member
According to the Moss catalog;
Ribbed face (early) ... the hole pairs are either vertical or horizontal.
Smooth face (late) ... the T and I have vertical mounting hole pairs, and the R, U, M, P, and H have diagonal mounting hole pairs.
Mickey Richaud
Kerry -
I MAY have a set at home - if you can wait 'til later today, I can check.
Mickey
Geo Hahn
According to Piggot... the smooth letters were introduced at TS 60001 -- but you will probably want to go with what matches the holes in your bonnet.
If your hinges sit on raised 'plinths' then you have a post-60000 body and perhaps you got the last of the pre-60000 aprons & letters. If you do not have plinths under the hinges then you have a pre-60000 body and a mystery.
martx-5
[ QUOTE ]
[/ QUOTE ]
I just went out and looked at the apron of the TR3 I'm restoring. It's a pre-60000 car and came with the ribbed letters. The hole for the "T" and the "I" are vertical, and the rest are horizontal. No diagonals.
Moss also states in their catalog that the actual changeover is unknown. I always though it started with the TR3B's, as this was the time that the smooth letters appeared on the TR4.
Andrew Mace
[ QUOTE ]
[/ QUOTE ]And I'm afraid Piggot is just plain wrong on this detail. My battered, but dead original, TR3A with commission number TS71909L had ribbed letters, and I've seen any number of post 60001 cars with same.
[ QUOTE ]
[/ QUOTE ]This theory is probably closer, but I'm not sure it was quite that late. The TR3Bs began to be assembled in calendar year 1962, well after the introduction of the TR4. Of course, the "smooth" letters used on the TR4 from its introduction date back to 1959 and the introduction of the Herald.
Meanwhile, there's been discussion amongst us Triumphal anoraks over the years about wide-mouth TR3 aprons. Most everyone knows that the TR body was retooled, and those retooled bodies started around commission number TS60001 (although I've seen at least one car, supposedly with its original commission number, with a late body and a pre-60000 commission number, so...?). The new tooling came about reputedly because the old, original body tools were wearing out. But remember that the wide-mouth apron had been introduced only a couple years before (and almost five years after the original introduction of the TR2), so it seems likely that the tooling for the wide-mouth apron still had some life in it at the introduction of the post-60000 cars. (Still with me? /ubbthreads/images/graemlins/grin.gif )
By now (TS60000+), Standard-Triumph was still cranking these cars out at a pretty good clip, so it seems reasonable that, at some point (perhaps around the time of the Leyland takeover?) the front apron tools had to be redone. At that point, it only would've made sense -- as much as anything in the auto industry, especially in Britain, ever made sense -- to "commonise" the lettering with the undoubtedly less expensive and plentiful smooth letters off the Herald and the soon-to-be-introduced TR4.
Over the years, some folks have observed a slight difference in the shape of the sheetmetal from the top of the grille opening back on later aprons with original smooth letters. But then there are also the very late aprons, some possibly having been fitted to TR3Bs, but most certainly being offered as repair panels; these aprons had no letters at all. I believe that was also the case for the Tasker Metal Products aftermarket apron that was available for many years through J.C. Whitney and probably other vendors as well. I've no knowledge of what might be available currently, but I'll assume that any available "new" replacement front apron has no holes for letters!
That's my story, and I'm sticking to it.... /ubbthreads/images/graemlins/crazyeyes.gif
W
wifegonnakillme
LOL, I love this forum...
Ribbed letter ordered for my newer old style inbetween TR3 body that is being freshly painted to be brought back to a former glory /ubbthreads/images/graemlins/crazyeyes.gif
Cheers,
Kerry
B Smooth vs ribbed case ? Spridgets 9
F Ribbed case tranny in 948 bugeye Spridgets 2
W Original ribbed rubber door liners Spridgets 4
I What kind of glue to use for ribbed bugeye panels? Spridgets 7
I Source for ribbed material for inside bugeye door? Spridgets 5
W SEM Color Coat and ribbed door panels Spridgets 13
EVSpriteGuy Oil for 1275 ribbed case tranny??? Spridgets 1
M 58 Sprite ribbed transmission issue [again] Spridgets 10
W Ribbed BE door liner Spridgets 5
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
F Wanted Smooth case trnny Spridgets Classified 6
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
M Smooth case front cover Spridgets 9
N TR2/3/3A Smooth TR3 Letters Triumph 6
M Smooth case gearbox in early MKII Sprite? Spridgets 23
apbos Awakening the Smooth Case Transmission Spridgets 7
I Smooth case transmission help please Spridgets 11
L How to smooth out a jumping fuel gauge? Austin Healey 20
rkep01 Question about front cover on smooth case trans Spridgets 5
I T-Series WTD: lucas 54382845 fuse box cover [smooth finish] MG 0
I WTD: lucas 54382845 fuse box cover [smooth finish] Austin Healey 2
S TR2/3/3A black wrinkle or black smooth,tr3 Triumph 5
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
drooartz Smooth case remote shifter on a rib case Spridgets 7
T Making straight cuts & smooth edges for patches Triumph 5
N tranny's for sale...smooth cases Spridgets 0
Woodie smooth running again,, educate me pls Spridgets 5
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
H Badge and letters -how to affix to car Restoration & Tools 1
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Tinkerman TR2/3/3A Apron letters "TRIUMPH" Triumph 5
H Commission Plate Numbers & Letters Triumph 8
A TR2/3/3A TR-3A Badge and letters finally Triumph 6
58Custom Decode letters/numbers on pistons Spridgets 5
zimmy MIDGET letters Spridgets 6
S Removal of hood letters Triumph 5
