Smooth case transmission help please
ichthos
I know my second gear/synchro at the very least will have to be replaced in my bugeye at some point. One of my strategies is to rebuild another smooth case transmission that Bill gave me so that I do not have down time. I know it will take some time to locate the parts I need. I have never rebuilt or inspected a transmission before and need some information.
1)How do you know if a transmission is close ratio or not?
2)How can you tell if a part is worn and needs to be replaced without having a new one to compare it to?
3)Would it be worth it to take it in some where and just ask them what needs to be replaced?
4)Besides the second gear/synchro, what else is typically replaced in a rebuild?
Kevin
Billm
Answer- use a ribbox, don't use a smoothcase for anything except show!
Sorry
BillM
Sarastro
I have two smooth-case transmissions, which are free to anyone who wants them. I'll list them on Craigslist, and if no takers, they're off to the recycling depot.
I don't have first-hand info, but I have heard that they are difficult to rebuild. Lack of parts, and some things require machining. The ribcase transmissions are far superior, and you can get a good one for not a lot of money. It seems like the logical thing to do.
jlaird
Pat, what a neat tag, OopsClunkThud. Got to love it.
Yes rib case bits will go in a smooth case. How, no clue. Why? Use a ribcase.
Miss Agatha is going to have a ribcase sometime this fall. Unless you are going Concourse why not? Not too many judges even that have a clue.
OopsClunkThud
Member
I'm not sure why I'd want the smooth case, even if it's only the case. I never seem to be able to leave anything stock so it's not a concourse thing. But, If it's possible to have the aesthetic of the smooth case with the parts availability of the rib case, then why not.
Deleted member 9684
I just had my smooth case rebuilt and 1275(ribcase) gearset added by Quantum Mechanics in Oxford, CT. I'm sorry I can't answer your questions, but John did tell me that there is a slight bit of machine work to be done in order for it to work.
I did it to maintain the original look for possible concours judging while also getting reliability and readily available parts.
personally, I think just giong the ribcase route is a better and cheaper idea.
smaceng
If it is ok, could I get the cost, seano?
Drop me a PM if you would like. Quantum Mechanics comes highly recommended!
Scott in CA
Brian_James
I put ribcase internals in a smooth case about 25 years ago, but can't recall the specifics. As I recall, it was not very involved. That is what is running in my car right now (when I can find time to drive it).
Brian
apbos Awakening the Smooth Case Transmission Spridgets 7
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
F Wanted Smooth case trnny Spridgets Classified 6
M Smooth case front cover Spridgets 9
M Smooth case gearbox in early MKII Sprite? Spridgets 23
rkep01 Question about front cover on smooth case trans Spridgets 5
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
drooartz Smooth case remote shifter on a rib case Spridgets 7
B Smooth vs ribbed case ? Spridgets 9
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
N TR2/3/3A Smooth TR3 Letters Triumph 6
L How to smooth out a jumping fuel gauge? Austin Healey 20
I T-Series WTD: lucas 54382845 fuse box cover [smooth finish] MG 0
I WTD: lucas 54382845 fuse box cover [smooth finish] Austin Healey 2
S TR2/3/3A black wrinkle or black smooth,tr3 Triumph 5
T Making straight cuts & smooth edges for patches Triumph 5
N tranny's for sale...smooth cases Spridgets 0
Woodie smooth running again,, educate me pls Spridgets 5
W ribbed or smooth letters... Triumph 7
R RIB CASE SHIFT LEVER Spridgets 0
R Rib Case rebuild... Spridgets 5
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
John Turney Getting Speedometer out of the Case Austin Healey 6
A Wanted Rib Case Transmission Spridgets Classified 1
A Rib case problem Spridgets 7
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
F Ribbed case tranny in 948 bugeye Spridgets 2
6 Spridget Radio/Speaker Case Spridgets 4
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
C TR2/3/3A Transmission case ID Triumph 3
B Tar case glass mat batteries Austin Healey 8
mailbox General MG In case anyone needs a project or parts MG 0
Rhodyspit75 General TR Just in case you're not on my Christmas card list. Triumph 3
T Basket case BJ8 values Austin Healey 10
B Purchasing Rib Case Spridgets 17
NutmegCT In case you need one - Other Cars 1
Gerard Source for front cover w/seal for rib case Spridgets 15
M crank case vent pipe Austin Healey 11
L How to repair cast aluminum transmission case Spridgets 26
jlaird Rib Case arrived Spridgets 13
britndablood FS 1098 with rib case in North Carolina Spridgets 0
K TR2/3/3A TR3A...Tighten Diff Case Bolts? Triumph 5
tahoe healey Ken's case Austin Healey 1
HerronScott Alternator in generator case project? Triumph 2
TexasSprite Tach Case Interior Colors MG 3
TexasSprite Tach Case Interior Colors Spridgets 12
