crank case vent pipe
AH100M
Most likely bad piston rings - combustion gasses leak past, pressurize the sump and this forces air/oil mist up the vent pipe. Sorry for the bad news.
Agree, rocker needs re-build. Take valve cover off and run the engine. If you see more than a dribble from any rocker arm then you have found your problem.
homebeforedark
I just replaced the rocker shaft on a BJ8. #9 rocker was so bad the oil squirted high enough to hit the open bonnet. Many times the shaft takes the wear and the bushings can be left alone.
Alan T
TimK
British Car Specialists on the West Coast and Healey Surgeons on the east coast can do this. You remove the shaft and pedestals and rocker arms and send them in. They replace the shaft and re-bush the pedestals and ream the rocker arms (I think--I had mine done 30 years ago, hard to remember the details, but it is a common Healey repair. You reinstall taking care to reassemble the oil banjo fitting carefully. A worn shaft will have deep grooves on the bottom of the shaft where the rocker arms pivot. Oil will shoot up in this case instead of dribbling out of the top of the rocker arms when the engine is running (idling).
EV2239
If the rocker shaft is worn, then oil pressure might be down as low as 25 PSI at 70 MPH. 40 psi on a hot engine is about what BJ7s manage with the standard oil pump.
Crank case pressure from the breather is as Bill says, worn pistons and bores.
Ash
I second Bob's advice. Rocker Arm Specialist did mine too. Great job and fast. I don't believe British Car Specialist do the work but farm it out. Best to have the experts do it.
AH100M
Do a compression test - this will help determining whether it's a worn rocker shaft or piston rings. Don't ignore the "both" answer.
B Crank Case vent pipe Austin Healey 2
lbc_newbie Proper crank-case venting with mods - 78 Midget Spridgets 33
Got_All_4 YIPS Took out 4&1/2 gal oil & gas from crank case Triumph 18
G How to Reduce Crank Case Pressure..... Triumph 5
7 Crank Case Pressurized MG 1
Nunyas crank case breather line... MG 1
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 30
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
