Wanted First Motion Shaft for a Austin Healey 3000 Centershift case
racerbuff
Badly need a usable first motion shaft for my 1964 BJ8 Centershift case. Or if anyone knows someplace that can repair the syncro friction surface???
thanks,
Buff
425-870-9160
R Repair a First Motion Shaft for a Austin Healey 3000 Austin Healey 7
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
W BN1 Gearbox First Motion Shaft Austin Healey 0
M MGB First Motion Shaft MG 5
4tecdog Play in first motion shaft on BJ8 Austin Healey 3
Tullamore BN1 3 Speed Transmission Third Motion Shaft Disassembly Austin Healey 3
T Ribcase Input/First Motion Shaft source Spridgets 2
zimmy first motion shaft bearing clip Spridgets 9
drooartz MGB MGB in motion MG 2
K GT6 Exhaust smell when car in motion? Triumph 5
B E Type rack and pinion motion Jaguar 4
A TR4/4A Lost motion lever - what is it for - TR4 Triumph 2
ez_pa_6 Artistry In Motion Triumph 1
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
WHT Rocker Arm Shaft Replacement Austin Healey 21
D XK150 Transmission Input Shaft Jaguar 1
Rut MGB 62-67 upper MGB steering shaft MG 3
G Installing New Rocker Shaft Assembly Austin Healey 3
D Spedo shaft direction Spridgets 6
Michael Oritt Propeller Shaft Hardware Austin Healey 6
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
T MG Midget 1500 crank shaft pulley Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
R TR6 Drive shaft orientation Triumph 3
S TR2/3/3A Replacing the cam shaft Triumph 27
S Removing Overdrive Shaft Lever Pin Austin Healey 7
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
P Wanted BN1 can shaft Austin Healey Classifieds 0
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
C Bugeye propeller/drive shaft- universal joint Spridgets 1
Walter74 Kent AH4 cam shaft Austin Healey 18
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
L TR2/3/3A Drive shaft question Triumph 5
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
J General TR Cam shaft upgrade????? Triumph 3
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
