Ribcase Input/First Motion Shaft source
ThomP
I am looking for a new or like new first motion shaft for a ribcase transmission. Does anyone have one or know of a source?
Thanks
Thom
Billm
Check with Paul Asgeirsson at Morrisservice. He has about anything in transmissions and is good to deal with.
Bill
ChrisS
I have a few if you need one. You can also try Tim Phillips, TimothyPhill@sbcglobal.net at British Car Repair in West Bend, WI. No economic interest, I just go some parts from him for myself and another member here. Seems like a decent guy.
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
TulsaFred Starting Ribcase rebuild Spridgets 15
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
Rut Ribcase Spridgets 3
N Ribcase Ratio's Spridgets 8
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
L Ribcase transmission with 948 engine Spridgets 8
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Ribcase tranny - painted or bare? Spridgets 7
drooartz Checking a ribcase transmission Spridgets 2
58Custom Who sells best ribcase rebuild kit? Spridgets 6
drooartz Shipping a ribcase transmission Spridgets 17
64rocksprite Ribcase - all the same? Spridgets 4
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
ChrisS Ribcase split washers Spridgets 1
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
A Ribcase transmission Spridgets 0
D XK150 Transmission Input Shaft Jaguar 1
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
J TR4/4A Removal of spigot needle bearing from input shaft Triumph 1
K TR4/4A Gearbox input shaft pilot bush.... Triumph 4
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
CJD TR4/4A TR3/4 Gearbox Input Shaft Triumph 8
S Your input on Kumho kr21 155/80r 13 tires Spridgets 21
J Clutch Problem - Seeking Input Austin Healey 4
bill_powell MGB-GT Considering a B/GT; Input Please? MG 19
T Input on BJ7/8 Parish top Austin Healey 4
Mickey Richaud Input Needed MG 12
T lubing trans input shaft splines; torquing pressur Spridgets 2
T Play in gearbox input shaft Austin Healey 6
