Ribcase Ratio's
nomad
Got to wondering what the rib case transmission ratio's were and since I'm too lazy to look it up thought I'd ask here. I'm sure I have the info somewhere????
Just curious.
Kurt.
Gerard
Just curious.
Kurt.
Kurt,
There isn't a single answer to that since there are a couple different gear sets. See this link:
https://gerardsgarage.com/Garage/Tech/TransPartsIndex.htm
At some point, I'll have to look up the different ratios and add them to this page. The ratios will be in the different shop manuals specification section.
N
nomad
Thanks Gerard, I didn't realize there was so much complexity to it all. I do remember reading there was a difference between the Mk3 and Mk4 ribcase ratio. Couldn't find the info in Bentley's but it's really not all that important. The Lotus group has a system for comparing transmission ratio's and that got me thinking.
Kurt.
Gerard
Kurt.
Glad I could be of help... :cheers:
N
nomad
Well, just to give a bit more info the formula compares different transmission's to an ideal by what the differences are between gears. I believe the ribcase has pretty good steps between the gears. I have driven some 4 and 5 speed's that had lousey spacing between gear's.
Kurt.
Rut
Straight cut close ratio...very noisy, but a good 'racer'.
Rut
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
TulsaFred Starting Ribcase rebuild Spridgets 15
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
Rut Ribcase Spridgets 3
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
L Ribcase transmission with 948 engine Spridgets 8
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Ribcase tranny - painted or bare? Spridgets 7
drooartz Checking a ribcase transmission Spridgets 2
58Custom Who sells best ribcase rebuild kit? Spridgets 6
drooartz Shipping a ribcase transmission Spridgets 17
64rocksprite Ribcase - all the same? Spridgets 4
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
T Ribcase Input/First Motion Shaft source Spridgets 2
ChrisS Ribcase split washers Spridgets 1
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
A Ribcase transmission Spridgets 0
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
R Changing BJ7 Differential Ratio Austin Healey 10
Hamish Racing General Tech Close Ratio Gears Triumph 2
J Experience with High Ratio Steering Box? Austin Healey 15
T Diff Ratio BJ7 Austin Healey 5
K TR2/3/3A 3.45 Diff ratio? Triumph 7
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B diff ratio British Motor Corp 3
Rut TR4/4A Which rear end ratio? Triumph 1
Editor_Reid Ideal water-to-antifreeze ratio Austin Healey 25
F Differential Ratio Sunbeam (Rootes) 3
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
A 2.84 ratio crown wheel and pinion Rover / Land Rover 5
H ratio rockers Austin Healey 3
S Overdrive ratio from 22% to 28% Austin Healey 15
R oil cooler need for 1500midget with 9:1 comp ratio Spridgets 3
hondo402000 TR% Air to Fuel Ratio Triumph 46
RAC68 Low Ratio Rear Austin Healey 5
RAC68 Air/Fuel Ratio Meter Austin Healey 17
